computer ?
  • Thread starter Thread starter keithnra
  • Start date Start date May 26, 2006
keithnra
53
  • May 26, 2006
If I am going to change my 89 LX from an Automatic to a 5 speed will I need another computer. Also what all will I need to get. I have bellhousing, shifter, pedals, and I think that is it.
83Mustang427TT
162
  • May 26, 2006
You need an A9L computer the auto puter doesnt have the fuel curves that the manual one has and I have heard it may cause a no start problem and also wont have the rpms to shift when you need to..
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 26, 2006
  • May 26, 2006
I have personally run both the A9L (5speed) & A9P (auto) on a 5 speed car. Both computers will work with no problems.
83Mustang427TT
162
  • May 26, 2006
I have heard that you can run the auto but it has a much lower rev limit then the A9L think I read it on www.fordfuelinjection.com also when coming to a stop the auto computer by way of a pip signal trys to stall the car out when in a manual equipped car...I could very well be wrong but Im in the process of swapping a 351W C-4 combo into a 4 banger and have done alot of research on the computer functions and which one to use A9P does have better fuel and spark tables but like I said there are some differences
wht93gtEd
29
Jersey Shore, New Jersey
May 26, 2006
  • May 26, 2006
But can't you only do this if the car was originally a 5spd? I know you can't run a 5spd computer in a car that was originally an AOD because of the whole pin30 thing with the NSS; but I think you can run an AOD computer in an original 5spd car?
To answer the original questioh, no, you don't have to change the computer.
83Mustang427TT said:
have heard that you can run the auto but it has a much lower rev limit then the A9L think I read it on www.fordfuelinjection.com also when coming to a stop the auto computer by way of a pip signal trys to stall the car out when in a manual equipped car...I could very well be wrong but Im in the process of swapping a 351W C-4 combo into a 4 banger and have .
you're right and wrong...
lower rev limiter = yes
stalling when stopping = no
It's been almost 2 years and 40k miles since I swapped my car from AOD to 5spd and it's never once stalled or almost stalled for that matter when comming to a stop. As a matter of fact it just perfect...just like a factory 5spd car would.
HISSIN50
34
129
May 26, 2006
  • May 26, 2006
In case it factors in (regarding post 2), another source of confusion if searching is that the AOD(E) computer (U4) will cause a bogging while driving along after a swap because that computer controls shifts electronically. It will hiccup when it knows it was supposed to shift. None of that should apply to the TV actuated tranny/computers.
keithnra
53
  • May 29, 2006
will an A9L computer out of a 92 GT work in a 89 LX if i am trying to change over from auto-5 spd. will the wiring harness wire right up with no problems. I guess my question is are all A9L computers the same 87-93?
GearHd6
459
Ashford, CT
May 29, 2006
  • May 29, 2006
You'll have no problems with the AOD computer when you do the 5 speed swap. I've done it with no problems. One thing that has to be done is the neutral safety switch HAS to be bypassed or you'll have a high idle condition as soon as you put the car in any gear other than neutral. The reason being is with the AOD, when its put in gear just from the drag from the converter its trying to drop the RPM's so the computer compensates by increasing the RPM's by a couple hundred.
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
J
Interior and Upholstery NEED HELP FINDING SHIFTER PLATE
  • Jschallitz
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
rednotch
