Motor has been sitting a long time. Today I went to drain the oil and only water was coming out, only dripping slowly though. So I removed the oil pan to inspect and the oil pan was full of oil with a little bit of water. The oil had a little bit of milky goo in it as well the oil pump screen was covered in it.
Is there a way to clean the bottom end while the pan is off? The Pacific Northwest has some of the highest freeze/thaw rates in the country and I think that's what happened. Everything in the heads and galley looks clean. Heads are still on and don't want to remove them unless it's as a last resort.
myself 1st time.
