confusing electrical problem
lilblueskeeter
22
Im having a slightly confusing electrical problem. I was sitting in my car yesterday and with the engine off, key off and flipped the toggle switch to turn on my fan and my stereo came on which has never happened before. and also with just the fan turned on, and now the stereo i can also roll my windows up or down. Does anyone have any ideas as to what may be causing this? Somebody told me that i have a direct short in my fan which is causing my current to back track through my electrical system? Any help would be appreciated
Thanks: Danny
Anybody have anything? I tried the same thing again this morning (turning just the fan on) and now i dont have any power to my stereo or windows with the fan on. which makes me lean more towards the fan being my prob. maybe 2 wires touching sometimes and causing it to screw up. need some ideas pretty quick cuz im having to drive it to work and back and im afraid it may really mess something up or catch on fire or something.
Thanks in advance.
Try wiggling your ignition switch and see if that is the actual problem if it seems that wen you wiggle the ignition switch this causes the problem to arise I would change the ignition switch because it is burnt up and it could cause a fire. I am not talking about the key part the part that is bad if this is your problem is the roller contacts that the key engages
Its just a 2 position toggle switch hooked to a 12V positive and to the control box. Its been set up like this for about 3 years and it just recently started this. I also noticed today, when i turned my key back to accessory my fan came on. (toggle was in the OFF position)
There's a chance that the current has fried the switch, so it backfeeds the circuit at times, and leaves it open at other times.
You might find melted wiring as well. If it's near the stereo and window wiring, it can cause issues. I would dissect the entire run of wiring and replace the set-up with a proper set-up (using a pair of remote relays at a minimum. This keeps high power wires out of your cockpit).
Do not use a simple on/off switch without using a relay. The current load can burn up the typical cheap automotive switch very quickly. The fan draws 30+amps and you need to use #10 wire on the fan power and ground wiring.
If you are good with electrical stuff (90% of the people here aren't), build your own controller. The numbers on the diagram (#86, #87, etc) refer to the numbers on the bottom of a typical automotive relay.
attachment.php
Note that the thermostat switch in the diagram isn’t really suited for the job. You’ll have to do a Google search and find your own.
Did you hook the toggle's ground to a bunch of ground wires? They sorta ping a certain voltage value is the ground completes the circuit. So, you use a ground box or J-box (junction of wires all connected), you can send the other J-box that does not use the first J-box is you take your toggle ground off the accessories or a j-box you may/may not be in?
I think it is your toggle to ground being you can send the hot 12v to your hot end of the component, but on the computer car with all that is J-box and you have that rev limiter with different grounds that use their own j-box so they can cut the coils, or A/C on the throttle up is shut that down for a second and all that window up and down is you an that accessory is ground the toggle on to the frame is no other wire to ground on the toggle.
No radio? Check fuses first thing.
