connecting rod install?
  • Thread starter Thread starter latamud
  • Start date Start date Nov 28, 2005
latamud
791
Tampa, FL
Nov 28, 2005
  • Nov 28, 2005
I did a search on spiral locks. In doing so I found a thread warning to make sure the rod is on the correct way. What should I be looking for to install the rod correctly? Thanks.
10secgoal
2,801
San Diego
Nov 28, 2005
  • Nov 28, 2005
If you are looking at the motor from the front, you place the piston so the fly cut, if any, are facing the middle of the block. The same goes for the slots for the bearings. The rod caps go on so the slots are on the same side and they face in the center of the motor.
rbohm
6,698
550
204
tucson,az
Nov 28, 2005
  • Nov 28, 2005
if this is a V8 then you need to install the pistons with the little notch facing the front of the engine, and the numbers on the rod facing the outside of the motor. also make sure that the numbers both on the rod and the cap are on the same side as well for proper rod cap alignment.
latamud
791
Tampa, FL
Nov 29, 2005
  • Nov 29, 2005
Thanks guys. I figured it had something to do with the bearing notches.
rbohm
6,698
550
204
tucson,az
Nov 29, 2005
  • Nov 29, 2005
actually the bearings dont have notches, they do however have a chamfer on one side, and that chamfer must line up with the crank filet radius on the outside edge of the crankpin.
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
