Control arm bolts
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Aug 23, 2007
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 23, 2007
  • Aug 23, 2007
I need to know the sizes for all 8 or a place where i can order a set.. The dealer is a no go..
stang&2Birds
2,091
New England. :-) CT/MA
Aug 23, 2007
  • Aug 23, 2007
http://www.breezeautomotive.com/details.php?prod_id=170&cat_id=34
RsStanG1987
569
9
79
Dupont PA
Aug 23, 2007
  • Aug 23, 2007
Thanks but i want a set not something im paying 7.50 each just to hack up.. Anyone else?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 23, 2007
  • Aug 23, 2007
You can check with Greens, but its probably going to be similar in cost.
SQUEEZE&STROKE
SOUTHERN CA
Aug 24, 2007
  • Aug 24, 2007
If you can get me a pic, I have about 200lbs of bolts from probably 10 mustangs. I know I have control arm bolts in there, you can have em if you want to pay for shipping.
EDIT: You need 8 of these?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 24, 2007
  • Aug 24, 2007
He was probably counting Nuts and Bolts to get to 8....
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Aug 25, 2007
  • Aug 25, 2007
No, there are eight bolts and eight nuts.
4 control arms x 2 bolts and nuts each = 8 bolts and nuts
The lowers are aprocimately 105mm in length (get 110) and the uppers are approx. 82 mm (get 90). The size is M12-1.75. The nuts are grade 10.9 or better.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 26, 2007
  • Aug 26, 2007
I was just thinking of the LCAs.
RsStanG1987
569
9
79
Dupont PA
Aug 26, 2007
  • Aug 26, 2007
thanks mang...
N
niklid05
140
Kutztown PA 19530
Aug 26, 2007
#10
  • Aug 26, 2007
  • #10
not that it helps on dimensions....but i went to ford and they wanted something insane for everything,36 bucks i think for all 16 pieces.... i paid 14 bucks at that part store for something similar. grade 10.9..
stang&2Birds
2,091
Aug 26, 2007
#11
  • Aug 26, 2007
  • #11
Similar, but *not* the same! The Ford bolts are coated to help reduce corrosion. If your junking the car within 5 years, then go with the regular 10.9 bolts. Otherwise, get the *correct* bolts.
RsStanG1987
569
9
79
Dupont PA
Aug 26, 2007
#12
  • Aug 26, 2007
  • #12
Ford told me they were discontinued.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 26, 2007
#13
  • Aug 26, 2007
  • #13
you could zap the bolt heads and threads with some paint or rust primer if you want, if you get regular bolts
4G-KDMP
935
CA
Aug 26, 2007
#14
  • Aug 26, 2007
  • #14
wouldn't zapping the bolts and threads w/ either primer or paint cause a bigger problem later if you ever need to replace them again?
i know you could always use a torch to help release the nuts from the bolt, but why do that if you can make it easier on yourself now by buying the correct bolt and nut now?
stang&2Birds
2,091
Aug 27, 2007
#15
  • Aug 27, 2007
  • #15
Painting them is not the same. Then, just get the bolts from the link that I posted at the top of the page.
These are OEM Ford, Class 10.9 Flange Bolts with anti-corrosion finish.
I know that some of the stuff I got from him did come in sealed Ford packages. He may have stock or access to the discontinued bolts. There is also a company that specializes in buying discontinued parts from Ford (at a deep discount) and then selling them. It clears out stock and space for Ford, the company makes money, and people can still get some parts (the parts don't just go into the trash). So, it works out for everyone.
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
