Control arms
  • Thread starter Thread starter 2fast4u770
  • Start date Start date Feb 22, 2019
2fast4u770
121
12
28
Feb 22, 2019
  • Feb 22, 2019
Ok so I don’t know if I need adjustable control arms. I plan on using coilovers and drop about 2 inches maybe, do I need adjustable upper and lower controls, or just adjustable uppers? Or just adjustable lowers? Idk or do I even need adjustable control arms.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Feb 22, 2019
  • Feb 22, 2019
If you are doing coil overs on all 4 corners, the adjustment in ride height is through the coil over.
If you are doing coil overs up front only, and conventional springs in the rear, then you need adjustable lower control arms with adjustable spring perches to vary the ride height. You don't need them, but it will help you adjust height to match the front.
Adjustable upper rear control arms don't have anything to do with ride height. They are for adjusting how far back or forward the rear axle sits to change pinion angle.
Reactions: a91what
2fast4u770
121
12
28
Feb 22, 2019
  • Feb 22, 2019
I know the control arms don’t adjust the ride height, I’m asking if I plan to lower my car are adjustable control arms needed or not
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Feb 22, 2019
  • Feb 22, 2019
Are you doing rear coil overs? If so, you don't need adjustable arms.
If you aren't, your ride height is dictated by the springs you use, or buying lower control arms with adjustable spring perches
Reactions: 2fast4u770
2fast4u770
121
12
28
Feb 22, 2019
  • Feb 22, 2019
I plan on using coils but I heard if you lower you car you need adjustable upper control arms to help with the pinion angle. Is this true
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
Feb 22, 2019
  • Feb 22, 2019
Ultimately depends on how low you go. You can certainly measure and purchase them later.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,952
5,831
213
Feb 22, 2019
  • Feb 22, 2019
At 2 inches drop it's a good idea to adjust pinion angle....so adjustable uppers would be needed for that.
Reactions: hrspwrjunkie and 2fast4u770
H
QA1 coilovers rubbing/hitting control arms
  • hassler
  • Sep 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
hassler
H
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Oct 21, 2026
phil2001svt
