Convert 2 piece main seal to 1
  • Thread starter Thread starter 65FBE2
  • Start date Start date Mar 1, 2010
65FBE2
283
Minnasnowta
Mar 1, 2010
  • Mar 1, 2010
Can anyone tell me if you can convert a early 2 piece block to a 1 peice rear main seal? I have 347 in a 71 block with a texas sized leak coming out the rear. I pulled the motor and we can find no reason for the rear main to be leaking. Any help would be appreciated
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Mar 2, 2010
  • Mar 2, 2010
This ain't a small block chevy. Just replace the rear mail seal and be done w/ it. Are you sure it is leaking though? Was the back of the intake leaking or maybe even one of the plugs on the back of the block?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 2, 2010
  • Mar 2, 2010
Replace your block with a late-model block. That's the only way.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Mar 2, 2010
  • Mar 2, 2010
The older blocks, pre73, have a higher nickel content and are therefore a lot stronger! Not to mention it is already machined and assembled.
65FBE2
283
Minnasnowta
Mar 2, 2010
  • Mar 2, 2010
I dopped the pan and replaced the seal twice. Even shimed it for a tighter fit (recommended by the engine builder for cronic leakers.) I have checked everything including the flywheel bolts and the intake. The block is dry with no sign of leaking behind the bellhousing on the block side. The pan gasket is not leaking. The only place left is the main. And it drips at a rate of about 1 drip every 5 seconds. Could it be the Crank? Is there a differents between a early 2 piece crank and a 1 piece? is there a slinger on the old cranks that does not exist on the new ones?
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
