convertable top
  • Thread starter Thread starter grc302
  • Start date Start date Jun 28, 2006
G
grc302
  • Jun 28, 2006
Have 1991 lx parts car that is a convertable,wiring harness is a rat's nest and engine is an anchor . Is there an easy way to raise and lower the top manually. I had a chevy (mistake!!!) convertable with a pressure relief/bypass on the pump so you could operate the top if case of pump failure. I realize I can disconnect the hydr cylinders, but I am looking for a simpler way first. I can not find this relief valve on the LX pump, and I can not find any literature on the subject. Any help you guys can give me is a plus.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jun 28, 2006
  • Jun 28, 2006
You can disconnect the hose from the pump, drain the excess fluid, and then cap the hose.
I just disconnected the cylinders from the top and it only took about 20 mins.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
