convertible diet
buy a notch. :)
i would do a lot of stiffening to improve it structurally (which adds weight). my point is that it can be done, but it is a bit more work than doing the same thing on a hard top. is this a whim or do you really want to drop some pounds?
good luck.
never again
This is why I am sellling my vert. I never had one and never will own one again. Reason is to heavy and way to much extra money to make it into a track car. If you like the bling crap and cruising its cool but hell Id rather buy a jeep with a soft top. Now I have a BA SVO and will never go back.
yea trust me id much rather have a hard top but im only 16 and i dont have a job so i kinda have to make do with what ive got. I want to try and get it at least into the 13.5 second range and im thinking that trying to get some weight out of it would really help. i got some performance stuff in it (exhaust, shifter, k&n, intake manifold) and i plan on doing a lot more and working on the suspension this winter too. but anyways is there anyway i could lighten it up some without sacrificing too much driveability? Ive got pretty good mechanical skills and a lot of tools including a welder and a bunch of fabrication stuff so thats not really a problem. The main objects are cost and streetability. any ideas?
I ran my 87 vert 13.90@100 on street tires. That was with 125k stock bottom end with thumpers ported e7te heads. a tmoss ported lower, and a comp cams nx264hr cam, 24# injs. I could have ran mid 13's ON SLICKS. and this was done with no weight reduction and I had 35# of tools in the car and I weigh 255# the race weight was about 3850# total. So you can do it.
if u want to sacrifice a/c then rip that out. other than that theres not really too much weight you can lose. rear seats are like 2 pounds lol. u can switch to a manual steering rack but i dunno how much that shaves, smog pump u need for emissions.
bottom line... you're heavy and stayin that way, so just make it up with a couple extra ponies and youll be fine.
this is off topic (kinda) so sorry but does anyone know how fast or how much torque a vert can get before the lack of hardtop gets to be a really really big problem, like twisting the frame or something? or does traction stop you way before that? just some random thought that popped into my head and i thought id ponder aloud. thanks
Ya know there's an 8 second vert in Drag Radial right now....
Anyways, the crappy thing is, like stated above, in order to make a very race-ready is to stiffen the hell out of it, and that means adding weight. The only real way to get it done is to just gut the whole interior, trunk and get as much fiberglass into the body as possible, like the hood and the trunk lid. I believe there's a lot of sound deadening meterial in verts....maybe start there. Pull the whole interior out and get all that sound deadening out from behind the panels, get aluminum seats, ditch the back seats (not that anyone over 10 can really sit in them). Verts CAN be made fast, but it takes a lot more power, a lot more traction and a LOT more effort.
wow, no one likes verts (i love mine). :)
if anyone hates theirs enough to sell it cheap, PM me! (LOL J/K. kinda).
if one really wants a realistic DD vert, i would look at what Tom (TMoss) has done with his. he has a very streetable, yet quick vert.
like i said, quick verts are not the cheapest thing to do (compared to a notch, SN GTS, etc). but if you love verts, there is nothing like 'em.
I own both a convertible and a hard top and believe me, it makes a difference. My vert feels sluggish compared to my notchback. I think the difference is also attributed to the fact that my notch is a 5-speed and the vert has an AOD. I still like the vert for just cruising around and the notch for some late night activity. :D
Fiberglass hood, fenders, drop unnecessary crap from front of car, keep all weight towards the back. If a gt, drop the support in the front bumper on the bottom for races, also, aluminum heads, aluminum parts, emissions crap, including heavy smog pump, and a/c because it's a convert, i dont think you need it so badly, all together, hood fenders, ac, emissions, and some other little crap, you could easily drop like 120 lbs from the front end and aluminum heads is like another 20, but thats expensive. keep in mind the convertible has added structural support underneath, so it's not as strong as a hardtop, but i would think it's stronger than t-tops.
Relocate the battery to the trunk. Put a set of long tube headers and a free-er flowing exhaust system on it. Replace the intake with a used GT40 intake. Replace the big one wire starter with a mini-starter. Put 3.73 gears in the car. Put a set of GT40Y303 aluminum heads on the car. Have a roll bar with the rear supports (not a cage - just a bar) welded (not bolted) in for a bit of extra structural support. Remove the silencer from the air cleaner and add a flat panel K&N filter. Bump the timing to 14 degrees btdc. I think the verts already have them - but if they don't add sub-frame connectors.
Those changes will add 60-75HP/ft-lbs of torque, will drop 50 lbs. of weight off the car, will remove 110 lbs. of weight off the front of the car, and will make a difference you can really feel - the gears will be especially helpful.
"how much torque a vert can get before the lack of hardtop gets to be a really really big problem, like twisting the frame or something? " The stock Stangs (fox)(notches and coupes) have VERY flexible unibodies - it's worse with the convertible. At stock power levels there's not enough torsional rigidity in the body/chassis. And it's even worse in the vert. Ideally, they need a well constructed roll cage to stiffen everything up if you're serious about increasing power/torque and having the car handle reasonably well.
Ted87GT - by the way, the performance changes I suggested will affect drivability. You will gain power and torque throughout the rev range - and with the gears, you'll have extra torque multiplication everywhere. They will make drivability BETTER. Fuel mileage will likely be the same or slightly better IF you can keep your foot out of it.
I have an 87Vert and I love it. My first time at Milan I got a 13.94 with a 2.25 60ft at 100MPH. I'm expecting better times when I get a good cumputer tune and a few more mods. So don't hate on the Verts it's all in what you like. They might be a little heavy but there is nothing like a vert on a summer night cruising with the tunes.
Ted87GT said:
ive got an 87 gt convertible and i want to take some weight out of it while keeping it streetable (its my daily driver). anyone got ideas?
A tubular K-Member will drop some much needed weight off the nose of the car.
At 3600 lbs, my car ran 13.8's without breaking a sweat on regular radials with 2.15 60' times.
Sad to see so many 'vert haters in here. I love my drop top, and some times I take it to the track. But it's no race car. Almost all of us spend 90% or more of our time on the street. You have to decide what you want more....a race car that's streetable, or a street car that runs at the racetrack from time to time.
