Convertible help needed Please
  • Thread starter Thread starter Curtis Harper
  • Start date Start date Apr 27, 2026
C
Curtis Harper
Kansas City
Apr 27, 2026
  • Apr 27, 2026
Hello all, please help a confuzed feller out. Trying to determine where the convertible top mechanisms are leaking on her 03. I don't know jack about hydraulics but trying to understand. When the top on the car is UP, is the fluid in the pump or in the cylinder?
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Apr 27, 2026
  • Apr 27, 2026
When the top is up, most of the fluid is in the cylinders. When you retract the top to put it down, the cylinders empty and most if not all the fluid is now in the pump. For this reason the pump needs to be filled when the top is down to fill to proper level.
Reactions: Bronco2fan
C
Curtis Harper
Kansas City
Apr 27, 2026
  • Apr 27, 2026
Thank you for that. So if the Cylinder is going to leak it would be when the top is up. If the cylinder seal was leaking it would blow oil out whle raising the top?
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Apr 27, 2026
  • Apr 27, 2026
Yes and yes, but it can also leak when top down if the leak is one of the hydraulic line connectors.
C
Curtis Harper
Kansas City
Apr 27, 2026
  • Apr 27, 2026
Thank you thank you. I think it's the hose, which I already have the kit. One video I watched said fill the cylinder, raise the top and then finish filling. Is that correct? If the fluid is supposed to return to the cylinder when it comes down, wouldn't that then be overfull and either lock up or blow a seal or line?
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Apr 28, 2026
  • Apr 28, 2026
There's a few ways to skin a cat, but ultimately final level needs to be set with the top down. Fill the pump to the top where it starts spilling out the spill plug. Run the top up and down 3-4 times and check and add to the level with the top down.
If you will with top up, when you lower the top the excess fluid will come out the fill port hole. So while you can certainly prefill the cylinder, just keep in mind all that fluid will return to the pump with top down.
C
Curtis Harper
Kansas City
Apr 28, 2026
  • Apr 28, 2026
Thank you!
C
Curtis Harper
Kansas City
May 25, 2026
  • May 25, 2026
How to get the air out of the lines? Just keep running up and down the top? Or pop one of the lines loose to let air out?
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
May 26, 2026
  • May 26, 2026
Just run the top up and down a few times, top the fluid off, rinse and repeat. Wou;dn't hurt to spread it out over a day or two to allow any accumulated air bubbles in the oil to rise to allow you to fully purge the air out.
Need help 94 GT convertible top leaking
  • Scott94gtvert
  • Aug 9, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 9, 2025
General karthief
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
R
2004 convertable help
  • realbkg
  • Jun 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 4, 2025
realbkg
R
R
Convertible top not closing
  • Ray _Sleeper
  • Jun 27, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 27, 2025
Ray _Sleeper
R
