convertible leak at rear window.
Dave Maher
I have a '94 convertible I just bought. It seems the back window is pulling away from the seal. Is there a special glue for this, or a right or wrong way to fix it. It hasn't rained since I've had it for a week, so I've still got time to repair it if I can
dave, sorry, but there is no real fix for the back window.. they cost about $180 bucks and are not that hard to replace if you're handy with a stapler... i put on my first mustang top ( i've done 3) in about 2 afternoons.. just take your time... convertibletopguys.com are some good people to deal with.. you can buy an easy install 1 piece top for about $295... temporary fix would be clear or black silicone.... good luck
Thanks, I'm ttrying to seal it up with vinyl glue around the window. I hope to seal the vinyl to the window and then use a vinyl repair kit to patch where the vinyl split. Then use silicone to fill in the gap between the glass and the vinyl. I'm about 1/2 way through. If that doesn't work, I'll put in a new window.
Dave
