On my '92 LX Vert...
Problem: Top goes up but won't go down.
Troubleshooting:
- Fuse panel fuse is good.
- Circuit Breaker under dash has 12V's on both sides.
- Relays just before the hydraulic motor are good(swapped them between each other, both work on the "up" connector).
- Both fuse links under hood by starter solenoid have 12V's on both sides.
- Dash switch replaced.
Other contributing factors to consider:
Ever since I picked up the car in '97 the top would always go down without engaging the e-brake. Only recently have I realized most late model Stangs typically have a safety feature that would not allow this(if I'm not mistaken??). Not sure why mine worked without the e-brake, but it sure made it convenient dropping the top at stop lights and slow rolls. Also, I recently had the entire interior removed to install a 6-point roll cage. I replaced the seats with some aftermarket ones, died the console and some dash parts black, new carpet and a new custom gauge cluster.
Upon putting everything back together I reconnected all the console wiring that had a place to go. Is there a connector at the e-brake handle which is part of the conv't top safety mechanism? I thought possibly it was disconnected before and I may have reconnected it, however with the e-brake engaged the top still won't go down. Is the new gauge cluster the culprit?
Really scratching my head on this one...any help is appreciated.
Troubleshooting:
haha jk
