  • 1994 - 1995 Specific Tech
Convertible top replacement questions
  • Thread starter Thread starter jermy82
  • Start date Start date Jul 30, 2006
jermy82
446
Sherman, Illinois
Jul 30, 2006
  • Jul 30, 2006
Okay, did a search and found a little bit of info, e.g. it's really hard and takes about 10 hours, but still had a couple of quick questions. Is all you need the top for about $150 if everything else is working fine? Also, what do you do with the back window? Thanks.
Z
zZsKyZz
503
Jul 31, 2006
  • Jul 31, 2006
I got my top for about $200 off 50resto.com. I set aside a weekend to do it, but you can probably do it in 1 day with help. There is a set of instructions floating around.. If I still had them I'd send them to ya. It's deff. worth doing it yourself. Just take your time and be careful.
95strokerPSU
986
Sacramento from Philly
Jul 31, 2006
  • Jul 31, 2006
If it's the original then it's probably time to replace it. Better to do it all at once then have to do double work. Go with a glass window, and if you have some extra money, get a canvas top....they look a lot better than vinyl.
Good luck
Dave
jermy82
446
Sherman, Illinois
Jul 31, 2006
  • Jul 31, 2006
Thanks guys. I know it might be a stupid question, but why would you buy a new window instead of using the old one? Also, it is actually the second top the car has had on it and everything else looks pretty much new, plus $$ is an issue, so I will probably just get the actual top.
95strokerPSU
986
Jul 31, 2006
  • Jul 31, 2006
Is the stang your daily driver? If you can afford to have it out of commision, or at least without a top, for week or two, then I would pull the top off and then inspect the window and see if it looks like it needs replacing. Then place your order. I got my stuff from www.topsonline.com
jermy82
446
Sherman, Illinois
Jul 31, 2006
  • Jul 31, 2006
That's a pretty good idea actually. I only drive it once every week or two anyway. Gotta love having a beater. Thanks.
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
