Convertible top replacement questions
jermy82
446
Sherman, Illinois
Okay, did a search and found a little bit of info, e.g. it's really hard and takes about 10 hours, but still had a couple of quick questions. Is all you need the top for about $150 if everything else is working fine? Also, what do you do with the back window? Thanks.
I got my top for about $200 off 50resto.com. I set aside a weekend to do it, but you can probably do it in 1 day with help. There is a set of instructions floating around.. If I still had them I'd send them to ya. It's deff. worth doing it yourself. Just take your time and be careful.
Thanks guys. I know it might be a stupid question, but why would you buy a new window instead of using the old one? Also, it is actually the second top the car has had on it and everything else looks pretty much new, plus $$ is an issue, so I will probably just get the actual top.
