Converting interiors
  • Thread starter Thread starter white86coupe
  • Start date Start date Jun 11, 2005
W
white86coupe
  • Jun 11, 2005
I am a new member to this site and i was just wondering if anyone has ever changed like the 79-86 style interior to 87-93 style. if so what all has to be done.
Stang89LXCPE
88
Wooster, O-HI-O
Jun 11, 2005
  • Jun 11, 2005
other than the dash, everything is a direct swap from 79-89. 90-93 uses three point rear seat belts. This becomes and issue if you want a black interior. Iswapped my 89 over to a 93 interior. Rear quater panels were differant, seat belts were differant (front and rear) and the rear package tray was differant (for the rear seat belt mounts)
Stang951
1,129
New Orleans
Jan 24, 2008
  • Jan 24, 2008
Stang89, did you add the rear 3 point belts to the swap, or did you just use lap belts instead?
I want to put the shoulder belts in the back of my 88 Coupe so the kids can start riding in the back.
88mouse
630
Mooresville nc
Jan 24, 2008
  • Jan 24, 2008
I just got all new black interior yesterday for my 88 coupe forgot all about the 3 point belts in the back. I took them to.(black interior came out of a 93)
Guess i will have to dye my seat belts in the back.
Mounting the dash is the hardest part. (swaping from 79-86 to the newer style dash)
Stang951
1,129
New Orleans
Jan 24, 2008
  • Jan 24, 2008
Did you pulll the parts from the donor car or were they already out? Curious to find out how the coupes had the shoulder belts bolted in.
If you don't end up using them let me know.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jan 25, 2008
  • Jan 25, 2008
If you plan to use the 87-93 center console, the e-brake handle has to be relocated, and the rear mount for the center console has to be put in place..
V
v8only
2,378
22
49
Jan 25, 2008
  • Jan 25, 2008
the 90-93 rear seats won't work in your car, nor will the 1/4 panels if you want to make it look right. 90+ quarters have seatbelt cutouts..if you don't fill those holes with a seatbelt, it'll look hokey. Also, the seatbelts are mounted higher on the piller, so you'll have to punch a hole in your quarters for your location, then you'll have a funky hole up there.
as for the 86 interior, why swap it? the 86 interior looks badass. It looks like a true fox musclecar should. Don't get me wrong, I love the 87+ cars, but the dashes look more like they came from a ford tempo than a mustang.
If you really must swap, the dash will swap, but it will require lots of work, including a COMPLETE massive rewire of the under dash electronics.
rear 1/4s from an 87-89 will bolt in, but won't look right with the 86 rear 1/4 windows...there will be a huge gap..so you'll have to swap the windows too.
for complete interior conversion on all fox years, check out my bro's tech writeup article.
http://www.thompsontransmission.com/techarticles/interiorguide.html
btw, cruise on over to foureyedpride.com forums and show off your 86!!
88mouse
630
Mooresville nc
Jan 25, 2008
  • Jan 25, 2008
V8only thanks for the info.
I'am only going to take the rear seat cover off and put it on my back seat. As far as seat belts the car is geting a cage, so I'am going to run 5 point harness in the front and back. So the hole on the 1/4 panels will be empty anyways.
How hard do you thing its going to be to put the dome light in? I took the headliner and the dome light out of the 93 to put in my 88. I want to do away with the map light and the 88 dome light. I like the 93 dome light better.
Stang951
I pull the interior my self. The rear shoulder belts are mounted on the flat spot in the back window. I believe they where 16mm bolt or torx bolt can remember. The fronts where #50 torx bit.
trbkrb
1,976
Houston, TX
Jan 25, 2008
  • Jan 25, 2008
I tried using a 93 dome light in my 87 and couldn't get it to fit right. The metal bracket that is welded to the roof is different for the newer dome light and it ended up sitting crooked. I ended up using a dome light from a 95, and it looks a lot better than any of the Fox ones IMO.
I ran the map light power from the stock front map light, and wired the rest to the door switches.
moterhead
Craigfield (near Fairview) Tennessee
Jan 26, 2008
#10
  • Jan 26, 2008
  • #10
If anyone will ever use those rear seat belts, get some black ones. Seat belts are made out of nylon. Dye won't penetrate. It just lays there waiting to smear on skin, clothes, etc.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 26, 2008
#11
  • Jan 26, 2008
  • #11
Just look for 79-83 lap belts for the rear. Black was available that year.
You can use the rear panels and not use the 3-point seatbelts. It won't look that weird.
I run lap belts with the black 3-point panels and it's never bothered me.
Here's a shot in the middle of my conversion (i hadn't changed the dash and center console yet so that's why they are still red)
88mouse
630
Mooresville nc
Jan 26, 2008
#12
  • Jan 26, 2008
  • #12
Thanks for the info. That 95 dome light does look alote better.
I'am planing on using 5 point harness anyways. The ones in the back will only be for looks anyway with the cage in the car. Thanks for the info tho.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
How do we feel about first gen fuel caps?
  • Teen'93stang5.0
  • Apr 25, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All May 3, 2026
General karthief
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
A
Red convertible in East Tennessee
  • Alexintenn
  • Sep 13, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 14, 2026
LILCBRA
