Cool fan issues
Hi everyone I’m having cooling fan issues my cooling fan will not kick on I have replaced my temperature control sensor and I have checked off fuses but when I unplugged the temperature control sensor the fan kick on so I know my fan is working I think that my CCRM may be bad could anyone else give me any ideas??
Just gonna put this out there. Can you use punctuation so I don’t run out of breath reading that run on paragraph?
It would also be nice if we knew the year, what motor, trans, and if any modifications have been done.
Reactions: DadLife0724
cant get codes dont have a scanner. No wire nuts the aftermarket doesn’t have any wiring issues it… the photo is the kind of temp gauge I have installed
The 94-95 5.0 blocks have two temperature sensors - one that feeds the gauge in the dash (the CTS), and one that feeds the engine computer (the ECT). If the ECT has failed and is sending random values to the computer, the fan won't kick on. Found that one out the hard way. A higher-end code reader an show PIDs in the computer, which includes the ECT values. I'm sure there's a way to test the ECT using a voltmeter, but I don't know how nor what values are appropriate.
I believe that if the CCRM had failed, the fan wouldn't turn on at all. Since the fan does turn on when you unplug the temp sensor, the CCRM is likely fine. You can also run the KOEO and KOER tests, which test if the fan runs. You'll hear it turn on for a bit during the tests.
