I just changed my T-stat and on the way home there was a major leak through the housing (I think). I also replaced the housing gasket. I was a little worried that I might tighten the bolts too tight and screw the gasket up....after it started leaking I stopped, let it cool about 15 minutes, and refilled the radiator (and replaced the cap b/c it broke in my hand). Then I drove home (2 miles) in stop and go traffic and didn't leak another drop.
So, I lost a full gallon in about 8 miles but then lost nothing in the last two miles. When I got home I checked the system and watched everything as I revved the engine...I found no leaks.
My question: Does it take a little while for the gasket to form a good seal? Maybe the leak was happening while the gasket was trying to seal....is this possible?
