hey guys I just built my first engine and when i started it up .It started leaking coolant from the headers on both side I dont know what this could possibly be I had my block machined and exchanged my head please help Johnny
And if fluid can come out of there you have an exhaust leak.Now, if coolant does leak from the passenger side exhaust pipe during a coolant pressure test with the car off what could that signifyThere is no need to replace the head bolts on the 302.
Until they break, they are just fine.
ARP's would be better, but unless your gonna spring for them, the stockers will work well.
Perform a Coolant Pressure test.
With the engine off, pressurize the coolant system.
You will find leaks with in a few minutes.
Normally, coolant doesn't leak from the exhaust, but rather from the heater lines or maybe the back of the block.
Most likely, the midpipe flange is where you first noticed the coolant.
It is probably getting there from somewhere else.
jason
