  • SN95 4.6L Mustang Tech
Engine Coolant leak from oil filter
  • Thread starter Thread starter jr273
  • Start date Start date Mar 26, 2026
J
jr273
Australia
Mar 26, 2026
  • Mar 26, 2026
Hi guys, I have replaced the oil filter on my 2001 4.6 litre 32 valve engine three times now using different brands of filter and still have a small coolant leak coming from where the filter screws into the housing. Am I missing something when replacing the filter? Leak is about 10 drops per day so does not affect performance but it is just annoying and I do not want it to get worse. Any help you could give would be appreciated.
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Mar 26, 2026
  • Mar 26, 2026
I’m assuming just a typo when you said ‘coolant’? This is purely an engine oil leak at the filter to filter housing connection?
Can you visibly see any cracks on the surface? Are you able to lay a straight edge on to make sure it’s not warped?
J
jr273
Australia
Mar 27, 2026
  • Mar 27, 2026
thanks for your comments but it is definitely green coolant not oil. I will check for cracks as you suggested though.
gkomo
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Mar 27, 2026
  • Mar 27, 2026
I’m not familiar with the 4.6’s but what’s above the filter on the engine? Anything that could be leaking coolant down onto the filter housing?
J
jr273
Australia
Mar 28, 2026
  • Mar 28, 2026
Yeh that is what I thought as well so I checked that thourghly and even put some dye in the coolant tank ran for 200 miles and check with UV light and no signs of any other leak except from the oil filter connection. That’s why I am really stumped. All suggestions are welcome thanks.
gkomo
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Mar 28, 2026
  • Mar 28, 2026
4.6’s don’t have some built in oil cooling system that has engine coolant running through the filter housing or something along those lines do they?
J
jr273
Australia
Mar 28, 2026
  • Mar 28, 2026
Yes the quad cam motors do have that but I cannot seem to find the source of the leak
G
GOvert
504
103
73
north central Tennessee Valley
Mar 28, 2026
  • Mar 28, 2026
Ford Modular MMR TraX Pack Oil Cooler kit 4.6 Mustang GT / COBRA [439159] - $661.99 : Modular Motorsports, Home of the worlds fastest Fords
Modular Motorsports Ford Modular MMR TraX Pack Oil Cooler kit 4.6 Mustang GT / COBRA [439159] - MMR TraX Pack Oil cooler System This kit adds a High efficiency Oil cooler for ALL 1996 -10 Models and remotely mounts the Oil filter to any location. With this cooler both Oil temps and Water temps...
www.modularmotorsportsracing.com
Google search for the simple cooler delete
P
Pinellas50
73
29
28
Tampa Bay, FL
Mar 31, 2026
  • Mar 31, 2026
A coolant system pressure tester often works well in trying to find unusual leaks like this. You can rent one from an auto parts store.
Reactions: Mcmahst
squeak93
2,352
419
164
Joplin, Missouri
Mar 31, 2026
#10
  • Mar 31, 2026
  • #10
Very common for the cast housing to start leaking with age. Either replace it or try to find the source/area of the leak and use something like jb weld or quick steel to seal it off. (I've done that before on a 96 cobra and it worked like a charm). Call it a hack or call it a way to save 650 or whatever the above part cost.
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Oil leak at filter housing?
  • robw13
  • Apr 22, 2025
Fox 5.0 Mustang Tech Apr 27, 2025
nickyb
  • Gulftown980x
  • Jul 29, 2026
squeak93
