Coolant Leak
  • Thread starter Thread starter 89 Saleen#455
  • Start date Start date Mar 1, 2004
89 Saleen#455
519
New England
Mar 1, 2004
  • Mar 1, 2004
Does anyone know if the Stant (or equivlant) Coolant Pressure Tester would identify coolant loss from the weep hole of the water pump? I'm not sure if the coolant is leaking from the water pump gasket or the weep hole? Would seem to me that the water pump would have to be circulating for the coolant to be expelled from the weep whole The car only has 41K original miles, so it seems unlikely that the water pump would need replacing? The last thing I want to do is throw a whole lot new parts on the car without knowing the exact cause of the problem. My other thought is the timing chain cover may be the root of the leak, but I'm sure the pressure tester would cover that scenerio. Any thoughts??? Thanks.
HO93LX302
715
Naugatuck,CT
Mar 1, 2004
  • Mar 1, 2004
Well if the timing chain cover was leaking you'd see oil.. As for the weep hole or gasket leaking on the water pump you'd see both when engine is running or at least until the coolant pressure drops.. I'd buy the eldlebrock high flow alum. water pump.. Haven't had any problems with it at all.. Been on for 2 years now.. It was only $150
89 Saleen#455
519
New England
Mar 2, 2004
  • Mar 2, 2004
Anyone else?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 2, 2004
  • Mar 2, 2004
Pressurize with the tester, then pull the coil wire loose, and turn the car over with the starter. That'll rotate the pump shaft around the seal. By the way, time and heat cycles are probably just as predictive of water pump seal failure as pure mileage is. Also, improper tension on a belt can take a brand new pump/bushing/bearing/seal out in very short order. So even if it's a gasket issue, I'd put a new pump on an 89 model car if I had to remove it to replace the gasket.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
