coolant leak
  • Thread starter Thread starter TorontoJohn
  • Start date Start date Jan 31, 2006
T
TorontoJohn
51
  • Jan 31, 2006
I have a coolant leak from the right passenger side of the motor. There seems to be a steady drip from one of the lower passenger side water pump bolts. Is this a common problem and can I fid it by tightening the bolt, or maybe a quick gob of silicone?
Thanks
John
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Jan 31, 2006
  • Jan 31, 2006
You can try. Just dont break anything, like a stud or that type of thing. Make sure that it isn't something simple like a hose that is leaking onto the bolt before you dig too far into it. Hopefully you aren't about to have to change the gasket on the timing cover/water pump!
T
TorontoJohn
51
  • Jan 31, 2006
Well it doesn't appear to be a hose leak or from the t-stat housing. It looks like a steady drip directly from the the bolt in question. There is no flow from other areas, it seems to just appear.
If I tear the front of the engine off I would be compelled to get a new water pump...probably edlbrock or something.
T
TorontoJohn
51
  • Jan 31, 2006
whooops double post
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 31, 2006
  • Jan 31, 2006
Let's face it... Chevy got the timing chain cover and water pump design right. Ford on the other hand... well you can use your imagination.
When I first picked up my most recent Mustang, I had a similar leak. Silicon will not work as a permanent solution. The proper way to fix it is to take off the water pump and reseal with a new gasket.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 31, 2006
  • Jan 31, 2006
Fix it right the firdt time. You could just do a temp fix with some goo for right now but fix it soon after.
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
