  • SN95 4.6L Mustang Tech
Coolant Leak
  • Thread starter Thread starter vote_no
  • Start date Start date Sep 5, 2008
vote_no
  • Sep 5, 2008
edit: 1998 Mustang GT
Don't know much about cars, so I figured you all might help. I've got a coolant leak, the origin of which is pretty uncertain. It leaks very quickly for a while, and then later stops. There's some coolant around the thermostat, so I've been told it is most likely the thermostat gasket not sealing properly. The thermostat makes a sort of repeated clicking noise after the engine's turned off.
The other interesting thing is that, earlier today, I noticed that the coolant level was very low in the reservoir, but then I drove it for a while and it was almost full. My understanding is that engines have an overflow reservior, is it possible that it's somehow been overfilled and that's why it's leaking?
I'm just grabbing at straws because I'd rather buy a $2 o-ring than go to a mechanic.
G
Gerardo
31
pasadena, tx
Sep 5, 2008
  • Sep 5, 2008
does your intake has the aluminum crossover or is it all plastic. if it is plastic you will need to replace your intake for the one with aluminum crossover.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Sep 5, 2008
  • Sep 5, 2008
The 98's do not have the alum. crossover. Right around where your seeing that coolant is where they are notorious for cracking. Thats what i am guessing has happened to yours. Sounds like a good time for a PI swap. Find out for sure first though.
fudleyd
180
Littleton, CO
Sep 5, 2008
  • Sep 5, 2008
This certainly could be the case here...
I still have my stock non-aluminum intake and have been lucky I guess. When mine does crack though I wanna upgrade to a roots blower...lol.
RandyStinchcomb
1,159
Randallstown, Md
Sep 7, 2008
  • Sep 7, 2008
not true, ANY 4.6 that has had the intake replaced wth the updated FoMoCo intake WILL have the aluminum x-over, even Non-Pi's....I do agree that it prob is a split/cracked intake and that a PI intake swap would be a wise choice.....
blubullett
535
Modesto, CA
Sep 7, 2008
  • Sep 7, 2008
Hopefully it is cracked I can hear it now..."honey, I need a new intake cause mine is cracked and the only one who makes one is kenne bell"
Mustang5L5
Mod Dude
Feb 18, 2001
43,363
18,107
224
Massachusetts
Sep 7, 2008
  • Sep 7, 2008
The coolant bottle on the 4.6l is not an overflow. It's a degas bottle designed to separate air from the coolant mix. Notice there is no radiator cap. The cap is on the bottle and is pressurized. If it's low, add some fluid.
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Sep 7, 2008
  • Sep 7, 2008
I know this but he never said his was updated. If its stock it plastic
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
squeak93
