Coolant overflow bottle?
  • Thread starter Thread starter grey5.0beast
  • Start date Start date Feb 21, 2008
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Feb 21, 2008
  • Feb 21, 2008
What the hell am I supposed to do to clean this thing up? I am putting my car back together this weekend hopefully and I am doing it with mostly freshly painted/polished parts. But that overflow bottle is so ugly and yellowish browny tint. Does anyone make a nice replacement? Or what have you guys done?
1.8kmint
47
Middletown, CA
Feb 21, 2008
  • Feb 21, 2008
ebay there like 50 bucks...
LiquidGT
368
Near STL hell
Feb 21, 2008
  • Feb 21, 2008
Canton makes an aluminum overflow that looks nice. Expensive though.click
NKau
1,346
Jefferson, WI
Feb 21, 2008
  • Feb 21, 2008
Go at it with a coarse wash cloth or a brillo pad and some Simple Green. If that doesn't clean it up, nothing will.
U
UnderdogGN
74
  • Feb 22, 2008
i have the canton catch can. Love it and it looks 10x better than stock.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Feb 22, 2008
  • Feb 22, 2008
Rattle can-o-paint. your choice of color just $4.99
Sicarius428
2,085
Feb 22, 2008
  • Feb 22, 2008
Canton looks awesome.
Kevin
grey5.0beast
Aug 3, 2004
atl ga
Feb 22, 2008
  • Feb 22, 2008
That canton does look sick. I am going to soak it in water with cleaner that has bleach adn see if I can't make it completely white.
ttop88
42
indiana
Feb 22, 2008
  • Feb 22, 2008
Paint it satin black. It will blend in that way.
D
Deleted member 87397
Feb 22, 2008
#10
  • Feb 22, 2008
  • #10
I have the Moroso catch can in mine and it looks nice and was not too expensive. They have a black one that is like 25 bucks or the nicer aluminum one for about 70. Ebay is also a good choice. Also, I dont' know if you've been there before or not, but there is a place in Clarkston called Prestige Mustang and all they do is Mustang salvage. Last time I was in there I saw tons of coolant overflows in all different conditions. You have to haggle with them on price though or they can be expensive sometimes for just salvage parts.
monte87
876
18
49
new york
Feb 22, 2008
#11
  • Feb 22, 2008
  • #11
I would honestly buy a stocker replacement from Laurel Mustang for $30. I went through a lot of bull**** with aluminum catch cans int he past, leaks, then not being able to see how much fluid was int here, blah blah- I mean-they look nice and all, But they are not large enough to allow the proper expamnsion of coolant, and not ebing able to visually see whats going on-Your gonna have a headache-been there and done that.
In my case-It killed me to remove the aluminum can, because-i have a fully polished fluidyne and the catch can was polished to a mirro-It looked nice, but that was about it. So i got another new sticker-and im a happy camper. Esp[ecially after blowing a H/G and not being able to see the milkshake in the solid aluminum catch can-Get my point!!! Its better to see whats going n, than to look coool.
Ciao Anthony
monte87
876
18
49
new york
Feb 22, 2008
#12
  • Feb 22, 2008
  • #12
Plus-the majoruty of aluminmiun catch cans only hold 1 quart of fluid, 2 at the most. The plastic stoicker is huge by comparison, can hold way more and never usually overflows when your on it, like the aluminum will when in throttle You'll see-the underneath area of the hood will sometimes be wet-from the condesnation which is misting out from the small threaded insert..
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Feb 22, 2008
#13
  • Feb 22, 2008
  • #13
50resto has em
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Feb 22, 2008
#14
  • Feb 22, 2008
  • #14
go to mustangs unlimited and get one, $30 and you live like 3 miles away...
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Feb 22, 2008
#15
  • Feb 22, 2008
  • #15
Someone (sorry, forgot whom) previously used some PVC and brass pipe fittings from Home Depot and rigged up a really sweet custom catch can for their Fox for pretty cheap. Spray that with whatever color of choice (black, presumably), secure it with a rigged-up bracket, and bickety-bam, you're set.
I don't like the stock overflow container because the way it's cast leaves that seam right down the middle that always inevitably splits and causes it to leak. Crappy design to start with.
LiquidGT
368
Near STL hell
Feb 22, 2008
#16
  • Feb 22, 2008
  • #16
Tell me about it, when I bought the car the seam was busted and cracked by the lower bolt hole, got a new one and it eventually leaked so I sealed it with RTV. And the cap doesnt fit right, crappy design indeed.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Feb 22, 2008
#17
  • Feb 22, 2008
  • #17
I've used the cheap one from Advance Auto for years with good results. Only until the last few weeks have I thought about using something else. I have mine placed beside the battery.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Feb 22, 2008
#18
  • Feb 22, 2008
  • #18
That's pretty much what I did on my '89 notch. The prior owner had a small Checker one on the side where the battery was, since he had the battery ghetto-rig-relocated to the trunk. When I put the battery back up front (never had the funds to do up the relocation NHRA-legal, myself), I got the bigger catch can from Autozone and hung it from the top bracket of the radiator with a bolt on one side and a zip-tie on the other. It's a little close to the belt near where the PS pump sits, but it still clears, and it's never caused any problems. Only paid like $10 for it, too. I just don't like the cap on the thing, because it's kind of a booger to get off - sort of like a milk jug with a snap-on lid that has no grippy edge to it.
Amazingly, the OEM overflow container on my '86 still holds coolant without leaking a drop.
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
