Coolant Overflow Issue After Intake Install
  • Thread starter Thread starter 88scar50
  • Start date Start date Apr 8, 2016
88scar50
22
  • Apr 8, 2016
I just got done installing a 93 cobra intake. Everything seemed like it went well but after a short test drive the engine started smoking a bit, After a quick inspection it seems that coolant is coming out under the cap of overflow reservoir. I figured maybe it was a bubble and raised the car and let it run for a while with the cap open then topped it off. Same thing happened. What's the deal?
stykthyn
5,232
2,652
223
gainesville
Apr 8, 2016
  • Apr 8, 2016
how long did you let it run? Did you run the heater as well?
88scar50
22
  • Apr 9, 2016
Around 10-15 minutes, heater was on
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 9, 2016
  • Apr 9, 2016
air in the system
88scar50
22
  • Apr 9, 2016
Any Idea how to fix this? Could it be a thermostat issue?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 9, 2016
  • Apr 9, 2016
http://www.stangnet.com/mustang-forums/threads/bleeding-air-out-of-cooling-system.574770/
88scar50
22
  • Apr 9, 2016
I have tried both the ways already and it didn't resolve the issue
88scar50
22
  • Apr 10, 2016
Gave it another shot. Jacked it up let it run for a while until I didn't see any bubbles then topped it off, then took it for a drive. About five minutes in I pulled over to check it and same thing, bubbling/boiling in reservoir and coming out of the overflow. Cleaning this coolant from the battery tray and continuing to buy more coolant is getting real annoying, any other suggestions for this stupid issue?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 10, 2016
  • Apr 10, 2016
Possible leak between the coolant passages on the throttle body spacer and the EGR passages. You get to bypass the coolant by using a piece of copper tubing to join the two small coolant lines. That will hold you until you decide to take the throttle body spacer off and replace both gaskets. While you have the throttle body off, check it for cracks, corrosion or damage to the throttle body passages and gasket surfaces.
Note the two small hoses on the throttle body; they are the coolant lines I was talking about.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif tang/tech/engine/images/mustang88VertTopMotorCkt.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
88scar50
22
#10
  • Apr 10, 2016
  • #10
I have the cobra intake which doesn't use the Egr spacer anymore, so those hoses are already connected together.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 10, 2016
#11
  • Apr 10, 2016
  • #11
Good, then keep looking. You need to find someplace where exhaust and engine coolant are in close proximity to each other. There are test kits that indicate exhaust leaks into the coolant.
A Google search turned up this gem ... http://www.autozone.com/repairinfo/...wTo&pageId= 0996b43f80a01231&subtitle=inspect
Even better is this YouTube video...
View: https://www.youtube.com/watch?v=a3J00_e7fyo
88scar50
22
#12
  • Apr 15, 2016
  • #12
After reading every post and thread I could find, changed out the thermostat again to the stock one and changed rad cap. No change, still doing it. This is getting very frustrating. Any other suggestions?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 15, 2016
#13
  • Apr 15, 2016
  • #13
Did you do the tests I posted for checking the coolant for a combustion leak?
Reactions: stykthyn
88scar50
22
#14
  • Apr 21, 2016
  • #14
I think that the problem has been resolved. I changed the fan clutch and haven't had the issue happen again yet.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
