Cantslowdown New Member Jun 20, 2004 502 1 0 Mt.Home AR! Jun 10, 2006 #1 Jun 10, 2006 #1 A guy at work said i can just unplug it and it will go off the wires that go to the overflow tank..Is this true and will it hurt anything?
urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Jun 10, 2006 #3 Jun 10, 2006 #3 my 95 used to have that problem, still does once and a while... if you pull the sensor out is there two prong like thingys at the end? if there is clean those up good and it should stop it
Cantslowdown New Member Jun 20, 2004 502 1 0 Mt.Home AR! Jun 10, 2006 #4 Jun 10, 2006 #4 A tech at work said just unplug it everything should be fine just making sure..
urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Jun 10, 2006 #5 Jun 10, 2006 #5 ya if you unplug it the light should go off, just check the level once anda while
4 46gtsblown Founding Member Jan 9, 2002 278 0 0 Jun 11, 2006 #6 Jun 11, 2006 #6 why not just fix the problem, it is not difficult.
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Jun 11, 2006 #7 Jun 11, 2006 #7 Check your coolant level
COramprat ...I can take it. I think. 20+ Year Stangneter Mar 2, 2003 8,474 1,463 223 Sea of Tranquility Jun 11, 2006 #8 Jun 11, 2006 #8 46gtsblown said: why not just fix the problem, it is not difficult. Click to expand... OK...so tell us how to do this if it isn't so difficult? This is tech...
Cantslowdown New Member Jun 20, 2004 502 1 0 Mt.Home AR! Jun 11, 2006 #9 Jun 11, 2006 #9 Update i just unpluged it no problems..I coolant level is fine..
CRZYHRSGT New Member Feb 14, 2004 240 0 0 5.7 miles north of THE Ohio State University Jun 11, 2006 #10 Jun 11, 2006 #10 46gtsblown said: why not just fix the problem, it is not difficult. Click to expand... This would be like unplugging an oil pressure sensor so when it is actually reading a problem you won't know about it until it's too late.
