coolant question
  • Thread starter Thread starter mat82284
  • Start date Start date Apr 14, 2004
M
mat82284
889
  • Apr 14, 2004
anyone know how much coolant do i need for an automatic 5.0 radiator??? (the car is a manual now just radiator stayed the same) also im going to do 70%coolant 30%water because my car runs at high temps so i want to keep it cooler or should i do 50/50??
T_5.0_N'works
260
Texas
Apr 14, 2004
  • Apr 14, 2004
Whats interesting is that if you use straight coolant, your car will over heat. It takes water to make it work to cool. Actually straight water is best to use if you don't ever have cold weather, it's just that water by itself will corrode pumps, radiators and all that good stuff. Personally, if you live in a hot area, I'd use a mixture of 70/30 water to coolant and add a bottle of water wetter. You should be set then. I would NEVER go past a 50/50 mix, unless it literally snows 6 months out of the year.
I don't know the amount you need, just make a mixture and fill it up.
M
mat82284
889
  • Apr 14, 2004
so 70% coolant then and 30%water thats right?? or did you mean the oposite also i live in california it gets real got and temps as low as 65
T_5.0_N'works
260
Texas
Apr 14, 2004
  • Apr 14, 2004
30% coolant, 70% water. Hotter climates you want more water than coolant.
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
