coolant surge??
  • Thread starter Thread starter mustangsquared
  • Start date Start date Sep 3, 2004
mustangsquared
828
new bern nc
Sep 3, 2004
  • Sep 3, 2004
Ok, I have an idle surge issue....also a cooling issue. I have a ton of that radiator sealer in my rad (which means it is all over the coolant system. I have been trying to flush all that crap out of the rad...if it is clumped up and gets in the pump...could it cause idle surge? My idle surge comes and goes for no reason. My thought (before I get flamed) is that if it clumps inside the pump it could slow it down/jam it and cause the engine to stain and thenthe ECU will attempt to fix it. Any ideas? SORRY SOOO LONG.
mustangsquared
828
new bern nc
Sep 3, 2004
  • Sep 3, 2004
For the surge I have done the following:
Cleaned IAD (Which is now disconnected with no change)
Replaced Coolant temp Sensor
Reset TPS
Reset timing
Cleaned TB and intake.
Any ideas?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Sep 3, 2004
  • Sep 3, 2004
i dont think that bars leak or whatever would cause any kind of stopping or straining of the engine, but it could definetly cause a cooling problem if it clogs passages in the radiator and block. your idle surge problems lie elsewhere. id try cleaning your maf and checking tps voltage.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
