  • SN95 4.6L Mustang Tech
coolent leak
  • Thread starter Thread starter shaunspengler
  • Start date Start date Mar 29, 2011
shaunspengler
51
west covina
Mar 29, 2011
  • Mar 29, 2011
i have a 1997 mustang 2v gt v8 4.6L i have a bunch of coolent on the v in the middle of the engine. can anyone help, if you have any info let me know or if you need any info let me know thank you
GDawg
1,469
Nevada
Mar 29, 2011
  • Mar 29, 2011
It's the infamous plastic coolant crossover leak... Does your plastic intake manifold have the plastic coolant crossover? If it does, then there is your problem.
See my sig for replacement pics.
shaunspengler
51
west covina
Mar 29, 2011
  • Mar 29, 2011
ok my engine is totaly stock besides intake so im pretty sure its the plastic intake etc. what parts should i buy to fix it and should i be worried about a rebuild?
johnnyt03gt
5 Year Member
Mar 15, 2008
453
dallas TX
Mar 30, 2011
  • Mar 30, 2011
you need to use some towels dry up the coolant.
start the engine. and watch closely to locate the leek. then take a picture of it and show us,
nyuk98gt
1,427
Chesterfield, MO
Mar 30, 2011
  • Mar 30, 2011
shaunspengler:
No, you need not worry about a rebuild. The intake is not difficult to replace.
You have some choices. You can buy the updated NPI intake with an aluminum crossover. You can buy the PI intake but it needs adapter plates ($$) or some installation tweaking (RTV dabs in the proper spots) to get it to seal just right. The NPI intake is quite restrictive and the engine power output is limited by this intake. The "PI intake swap" is a very popular modification and it is well documented in many, many threads here and on other Mustang boards. If you are mechanically inclined, I suggest that you go with the PI intake. If cash is tight then the cheapest option is the NPI intake with the aluminum crossover.
The coolant may have gotten into the sparkplug wells. If it has then the engine will develop a miss. At least you know what to look for. Sop up what you can with shop towels. Get a can of compressed air (keyboard cleaner at Office Depot/Office Max/Staples/etc.) and blow out the remaining moisture. Dry off the sparkplug boots and put a tiny dab of dielectric grease in the boot and swab it around. Just be careful pulling the boots off because you don't want to break a wire.
I will try to find some threads for you to read. Somebody here did a nice write-up, complete with pictures.
Welcome to StangNet, too!
HTH,
Chris
bhuff30
6,037
35
129
Olathe KS
Mar 30, 2011
  • Mar 30, 2011
There is a heater hose that goes right down the middle of the V, underneath the intake manifold. While it should be fairly reliable because it is mostly hard line, be sure to check it and the rubber hose going to it at the back of the engine.
nyuk98gt
1,427
Chesterfield, MO
Mar 30, 2011
  • Mar 30, 2011
bhuff30:
Excellent point! The o-rings on the water pump nipple may have gotten tired or the heater hose at the back may have broken.
Keep up the good work.
Chris
shaunspengler
51
west covina
Mar 30, 2011
  • Mar 30, 2011
thanksthanks to everyone who tried to help
thanks everyone but i actualy fixed it myself. i had some bolts loose neer the alternator and tited them worked great thanks for all the advice everyone=)
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
