Cooling fan not coming on
Powell123
I have a 95 3.8L v6 and the fan will not come on. I tested the wires using a volt meter and the fuse is only getting 6volts, when the fuse isnt plugged in. When I do plug the fuse in it gets no power. I can directly put power to the fuse box and the fan will work. Any ideas why this is happening?
Welcome to the boards!
Have you looked at the source wire to the fuse?
I don't follow about the fuse. If the source-leg shows voltage w/o the fuse installed, both legs should show voltage after the fuse is installed.
