  • SN95 4.6L Mustang Tech
Cooling fan wiring
  • Thread starter Thread starter Silvestris
  • Start date Start date Feb 27, 2012
Silvestris
28
Crown Point, Indiana
Feb 27, 2012
  • Feb 27, 2012
Hey! My stock cooling fan on my 96 GT seized up so I ordered an aftermarket dual motor cooling fan with 2 wires per fan. I want to be able to hook it up to the factory 3 prong connector so it'll operate like normal. Does anyone know what the 3 prongs on the connector are for, and have any suggestions on how to wire it?.
trinity_gt
3,125
81
99
Canada
Feb 27, 2012
  • Feb 27, 2012
The factory fan is a two-speed unit. The factory harness will have connections for low-speed (red/org), high-speed (org/light blue) and common (blk).
You might try wiring one fan to the low-speed feed and the other to the high-speed feed, returning them both on the black common. You should consider using relays on each of the feeds in case the fans require more current than the OE circuit is intended to deliver.
Silvestris
28
Feb 27, 2012
  • Feb 27, 2012
Perfect! Thank you!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Feb 28, 2012
  • Feb 28, 2012
Check out the following thread on how to wire a two fan unit to the factory CCRM.
http://www.stangnet.com/mustang-forums/threads/mishimoto-cooling-fans.823790/#post-8293761
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Z
Cool fan issues
  • Zipcity
  • Dec 23, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 27, 2025
manicmechanic007
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
