  • SN95 4.6L Mustang Tech
Cooling fan woes -- ccrm, sensor or ???
  • Thread starter Thread starter jfryjfry
  • Start date Start date Sep 11, 2008
J
jfryjfry
  • Sep 11, 2008
96 gt, everything worked great until a week ago.
normal behavior is that the coolant temperature is on the "O" in 'normal', give or take.
last week it started living in the middle/high zone when driving around town, and was normal on the freeway.
after a LOT of research online and on the car, my problem is that the fan is not coming on until the temp is around the "A-L" in 'normal'.
it APPEARS that the low-speed function is not working.
if i unplug the driver's side coolant temp sensor the fan goes on a lower speed for a second then jumps to a higher speed and stays there until i plug it back in. after a few seconds it shuts off.
if i turn the ac on max, it will turn the fan on to the same higher speed that the fan runs on when the sensor is unplugged.
so it appears that the coolant sensor is telling the eec the proper temperature, but that the ccrm isn't turning the fan on until it gets really hot.
it looks like the ccrm has, among several other relays, a low-speed relay. i wonder if that has gone bad? i pulled the ccrm out and apart but there is no way to check the condition of the relays.
so.... any educated guesses?
which relay in the ccrm is the low-speed fan relay or is there even one???
thanks in advance guys!
Jeremy
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
V
Cooling fan low speed not turning on
  • vman
  • Feb 27, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 24, 2025
vman
V
