Cooling Problems! Help!
  • Thread starter Thread starter Lynx331
  • Start date Start date Sep 11, 2004
L
Lynx331
308
Chicago IL
Sep 11, 2004
  • Sep 11, 2004
I installed a cobra intake on my car and now i run a whole notch hotter??? Its really bugging me. Im going to post a picture up the red section is where it runs now, and the blue line is that max it would run before with the other intake.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Sep 11, 2004
  • Sep 11, 2004
damn somethings wrong with mine then cause i run that hot on a good day, although im getting a new fan shroud so that should help since i dont have one...
04sleeper
2,674
14
89
Dallas, TX
Sep 11, 2004
  • Sep 11, 2004
I have found through experience that the factory gauge is not very accurate. A number of things could cause it to read a little higher than normal.
Since you said you just changed the intake, did you put in a new thermostat?
Did you just swap over the coolant temperature sensor from one intake to the other and not get a new one? Did you clean the contacts for the sensor?
I would try to get a hold of a good gauge like Autometer and see what the actual temp is. This is the only real way to tell what your temp is running at.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 11, 2004
  • Sep 11, 2004
I'm with sleeper - you don't really know what temp it's running at until/unless you get an accurate aftermarket gauge in there. I'd do that before I tried to troubleshoot any further.
T
t-top 87
23
  • Sep 11, 2004
I also agree an aftermarket gauge is a good investment. I will have one in the near future. From the looks of your picture, I'm assuming your running a 180 stat? Is the coolant system full, no air present. Does it run at different temps while idling as apposed to highway driving? I recently replaced my waterpump and after this I ran hot real hot. It turned out to be bad ground in the start cable, which was messing with the temp sending unit. Some this to consider.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
