  • 1994 - 1995 Specific Tech
cooling question
  • Thread starter Thread starter cbarr300
  • Start date Start date Aug 28, 2007
C
cbarr300
746
goose creek, SC
Aug 28, 2007
  • Aug 28, 2007
Ok, here's the scoop: (cliffs at bottom)
The car runs at 185* while cruising around town.
Once I get to, say, a parking lot and look for a place to park, the temps will climb up to about 210* or 220*.
Once I'm at a dead stop the temps will start creeping back down.
If I'm staying at idle and I rev the engine up I can see (instantly) the temp drop a couple degrees.
Here's the thing that stumps me: If I'm take off from a stop the temps will shoot up 4-5 degrees and then come back down once I'm cruising around...but if I'm going a steady speed and get on it the temps usually drop a degree until I come back to a cruise where they rise back up to 185*.
My high-speed is turning on and I do have pressure on the upper radiator hose. I did a coolant system pressure test and it held the pressure.
There's only two things I could think it would be. Either my waterpump is on it's way out....and the reason it cools when I rev it is because the blades are pumping more water through.
orrrr, I have a bad headgasket and combustion gasses are getting into the coolant when I'm taking off and since I have a fluidyne it can handle (somewhat) the extra heat. There's no signs of a blown headgasket though. The engine doesn't have a miss and there's no oil in coolant or vice-versa. I'm gonna do a compression test once I get the time.
I'm gonna try and hook it up to a sniffer, too
Any ideas....I'm stumped.
Cliff: getting warm on take-off. Pressure in upper hose. both fan speeds are working when they should. cools down if I rev it at an idle. No signs of blown headgasket (will do comp. test later on)
TrueBlue95GT
966
Connecticut
Aug 28, 2007
  • Aug 28, 2007
If I had to guess, I'd say waterpump....but if you change it, I'd also replace the thermostat and radiator cap while I was at it...
Stanger007
2,015
Baton Rouge, LA
Aug 28, 2007
  • Aug 28, 2007
Are you running stock fan temps in the EEC? Stock settings IIRC are around 210-220 for the high/low fans.
Wes
C
cbarr300
746
goose creek, SC
Aug 28, 2007
  • Aug 28, 2007
I'm running modified fan settings.
I checked my compression and one cylinder has 30 and the other one next to it (the one someone dropped a washer in), had 120...the rest had 145-150. Also, I drove it for a while today and noticed coolant level was getting lower.
It's funny though, it's not putting out any white smoke and I can tell it's a LITTLE down on power...but it pulls nice and strong. Guess it went in just the right place.
I didn't have any detonation or any overheating....gasket was installed properly....go fig
I'm pretty close to getting my new long block and other than the coolant level dropping and the weird temp thing I never would have noticed a blown headgasket...btw, it never overheats...just gets warm (220 which is hot by my, and most other people's standards).
ah well
Dino Dino Bambino
1,673
90
79
Cyprus
Aug 29, 2007
  • Aug 29, 2007
It sounds to me that your coolant temps. are behaving normally except that you almost certainly have a blown head gasket. You'll probably find the spark plug on the low compression cylinder is either wet or stained brown by coolant.
I recently had the same problem and found the head gasket was blown between the water jacket and the combustion chamber of cylinder no.1, so of course there was no mixing of oil and coolant; just the odd puff of white smoke from the passenger side tailpipe at idle. I used the opportunity to home port the heads and lower intake while they were off, and the heads were milled 0.010" resulting in a 0.14:1 compression ratio increase.
C
cbarr300
746
goose creek, SC
Aug 29, 2007
  • Aug 29, 2007
yeah, I think a new longblock would fix it. nothing major though, before I was wanting a 351 based beast....but I think I'd be perfectly happy with slapping my s-trim on a 331 with some somewhat mild heads.
baglock1
The Bartender
6,612
Space Coast, FL
Sep 1, 2007
  • Sep 1, 2007
What are you using to measure the temps? Hopefully a quality aftermarket gauge?
C
cbarr300
746
goose creek, SC
Sep 2, 2007
  • Sep 2, 2007
of course, the stock one's crap
I'm running the autometer cobalt full sweep. I'm gonna tear into it tonight maybe and change the headgasket out
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
