cooling
  • Thread starter Thread starter monkey420
  • Start date Start date Feb 6, 2008
M
monkey420
  • Feb 6, 2008
k i have an 1986 gt, and i want to change the rad and fan, is it better to go to an eletric fan or what, any suggestions would be great, for mods its just got under drive pulleys and 1 5/8 equal length shorty headers and full exhaust
M
monkey420
  • Feb 6, 2008
so can anybody help me...
9
92BlackGT
182
Tinker AFB, OK
Feb 6, 2008
  • Feb 6, 2008
if you don't have a 130 amp alternator, you may not have enough juice for an electric fan. Before I did my electric fan upgrade, i was having cooling issues and a new fan clutch worked wonders.
sahtt57
  • Feb 7, 2008
I'd just make sure your stock fan is working correctly [like the clutch actuating at the right time] and no fins are broken/damaged. Beyond that, try to get an aluminum radiator or one that is higher capacity. Filling it up with engine ice or water wetter is also a good idea to increase efficiency, if you are in a colder climate the water wetter is not an antifreeze. Look here, there are some great discussions.
The alternator needs to be bigger. There are many benefits to an electric fan such as no belt to spin, better cooling capacity, etc.
HISSIN50
34
129
Feb 7, 2008
  • Feb 7, 2008
Why are you changing those parts at all? Knowing that will probably help tailor replies.
Good luck.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 7, 2008
  • Feb 7, 2008
I installed a 3 core aluminum ford racing rad. Very nice piece. Very happy with it. As far as electric fans I have a black magic. I think the black magic extreme would be a better fan since it flows more. A alt upgrade is a good idea.
M
monkey420
  • Feb 7, 2008
im changing it cause my rad is done, last year on the way home from internationals, the car was running at 220, and on the way up it was running hot to, so i took the thermostat right out and that didn't even help, so thats why i was wondering if im changing the rad, if there is any advantages of going to a electric fan...
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
