  • SN95 4.6L Mustang Tech
COP question
  • Thread starter Thread starter evendal
  • Start date Start date Jun 22, 2005
E
evendal
28
Peterborough Ontario. canada
Jun 22, 2005
  • Jun 22, 2005
Just got plugs changed and noticed that one of the screws that holds the COP in place on the plug is broke off. I imagine the screw was cross threaded and then broke off. Will this hurt to drive the car with the COP just sitting on the plug and not secured down over the plug. The car seems to run ok.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 22, 2005
  • Jun 22, 2005
It should be ok but I would take it back and make them fix it
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 22, 2005
  • Jun 22, 2005
it'll still run fine. the boot is attached pretty snugly onto the plug, and if you develop a miss it'll be pretty easy to find
is the screw broken off into the head?
my_03GT
186
DE
Jun 22, 2005
  • Jun 22, 2005
Screw extractor set, then tap.
E
evendal
28
Jun 23, 2005
  • Jun 23, 2005
I had just had a 1.7L KB installed and when I got the car home and started looking at things I notice that the on COP (third back on drivers side) was loose. The screw was not all the way down was just sitting in the COP broken off. The car seemed to run good. The screw actually threads into the aluminum intake of the KB. I hoping that a good shop will be able to get it out and have it repaired.
twogts4us
4,188
12
79
Dunedin, FL
Jun 23, 2005
  • Jun 23, 2005
I'd agree, but take it back where? He didn't say anything about having it in for service anywhere...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 23, 2005
  • Jun 23, 2005
Well he said that he "just got plugs changed" which kinda sounds like he had it done by someone else. He also stated that he discovered the broken bolt which also implies that he was not present during the plug installation. I guess I just assumed he had it done in a shop...?
E
evendal
28
Jun 23, 2005
  • Jun 23, 2005
It was done at the shop that installed the KB. I am not sure if the bolt had bottomed out or what. The instructions said to use the same OEM bolts that came with the COP. All I know is that it will have to be drilled out and fixed. I wasn't around when this part of the install was done. I wish I was.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
