Correct Bulb # for 1967 Deluxe Door Courtesy Lights?
65and68Stang
148
Raleigh, NC
Could someone provide the correct bulb number for the deluxe door courtesy lights for a 67/68? I took out mine to buy some extras and there are two different numbers:
62-025/9? L6278
and
W1178
I'm not sure if either of these bulbs work, the lamp housings are not installed yet.
Thanks!
Kelton
Alot of part numbers have been superceded/replaced with different numbers now. Usually the only difference may be the candlepower (brightness) of the bulb. I ran into this with my hood mounted signal lights. Your parts store should have a book that interchanges your number with the new part numbers.
Use whatever bulb that you want to, as long as it fits the base/socket right and makes a good connection. Like 68GEETEE said the only diff. will be the brightness of the bulb. For example im using 6 volt GE 44 bulbs in the hood turn signal flashers, and they are much brighter than the 12 volt bulb, and i like it better that way.
