Engine Correct Gap For 1991 Mustang GT With Motorcraft Plugs
Imatk
100
10
29
So looking here
https://lmr.com/products/79-93-fox-body-mustang-spark-plug-gap-specs
It shows that the correct gap for my car (completely stock) is .054
So that's what I set the gap to... BUT... then I realized the plug I was using is NOT the "ASF-42" since you pretty much can't find that plug anymore.
The one I installed was "ASF-42CA."
So I'm wondering if the gap is too large on the plug since it's not the same plug?
Or is .054 correct?
Car seems to be running correctly, but the gap on the plugs I pulled out was more like .045 or something (the dealer did the plugs last not me).
Thanks for any help!
As noted, your good. Good work getting them changed out.
When I first bought my 87, it ran pretty well overall and I was happy with it. I knew i was going to do a full time when I installed the new headers and I could tell the motorcraft plugs in it looked very old.
When I pulled them I was shocked. They had to be the OEM plugs, they were worn so hard the gap was .90 plus! A prior owner installed an msd blaster coil which probably helped, but still. I was suprised it even ran at all, let alone as good as it did. Crazy stuff.
