I am trying to figure out what extra things I will need to build a 347 that I wouldn't have to buy for a 306. So far I have figured:
Crank (cast will outlast the block right?)
Rods (I or H?) I will probally go with a DSS or SCAT kit.
Balancer (have romac SFI now, could sell to take the bite off)
Flywheel (wanted to go aluminum anyways)
Extra machining for rod clearances
Am I missing anything???
I am starting to plan on rebuiding the engine if the results of the compression and leakdown tests are not real good. 15 years and 156K miles, smokes, blowby, maby it is time. I have been considering after all is said and done the HP:$$ ratio would be worth it to go ahead and stroke it, not to mention the torque.
My engine combo now is the stock 302 bottom end, Thumper heads, B cam on 1.7's, a 70mm TB, Edelbrock Perfomer Intake, Longtubes, and other supporting components. I am aware that many components on my engine would not feed the 347, but I would probally still have more power over a 306, plus I can upgrade next year. I am on a budget, but won't halfass it either.
believe me, i know how you feel. Its gonna be tough doing my combo but I should be happy once its done. Im waiting to hear from my cam grinder if he says I shoudl port the heads or not. If so, I will have that done first since I cant order a cam till the heads are done and flowed and wil order the shortblock at the time of the cam so it can be shipped to the shortblock builder and installed and degreed as part of his normal routine in the labor.
