  • SN95 4.6L Mustang Tech
Cost to replace intake valves?
  • Thread starter Thread starter GTFTW
  • Start date Start date Feb 5, 2012
G
GTFTW
51
  • Feb 5, 2012
I was wondering if anyone could give me a ballpark figure on how much it would cost to replace the intake valves or much work is involved?
trinity_gt
3,125
81
99
Canada
Feb 5, 2012
  • Feb 5, 2012
Heads are coming off, complete disassembly and cleaning, source and install new valves and lap to the seats (grinding seats may be necessary...), new seals, reassemble and re-install with new gaskets: If you have a shop do it you're probably looking at $1500 or more. Unless you have bux invested in port work on the heads or they are aftermarket already, you're probably better off simply replacing the heads and using the old ones as cores or selling them on ebay to recoup some costs.
Q: Why do you need to replace the intake valves? PTV?
G
GTFTW
51
  • Feb 5, 2012
HOLY SHEET! Wow, was not expecting that. Ok that idea is out the door lol
Yeah. I am just throwing around the idea of some stage 2 cams, namely the hitechs, but the PTV issues with them have me worried
Rick 91GT
Mustang Master
95
99
PA
Feb 5, 2012
  • Feb 5, 2012
Yeah $1500 is a decent estimate depending what you do while the heads and front of the motor are apart.....Id go TFS
evolucion311
236
Feb 6, 2012
  • Feb 6, 2012
I recently had to machine both of my heads to fix bad exhaust valve seals....
It wasn't fun but I learned a LOT. If you have the right tools, patience, and plenty of beer you can remove and install the heads yourself. I would most definitely have a machine shop with a good reputation do the actual head work itself.
You only need a few special tools like cam shaft holders, crank holder, etc., a load of sockets and extensions and u-joints and wobblers......
Make sure you do the job in a clean place not exposed to the elements and that you replace every gasket that you break the seal on. Rockauto DOT com has great prices on Felpro gaskets.... much better prices than the 'Zone.
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
