Could clutch cable be my problem?
  • Thread starter Thread starter Dtowncats
  • Start date Start date Mar 13, 2004
D
Dtowncats
340
York, PA
Mar 13, 2004
  • Mar 13, 2004
When I let my clutch out (I know everyone is thinking t/o bearing) something makes a loud humming noise. This noise also gets louder when i rev my engine. I really don't think it is the throwout bearing because I had as brand new one installed last August along with a new clutch. Also as I press in my clutch, when it gets a couple inches away from the floor i hear a click. Any ideas because i am stumped.
StreetStang37
451
San Jose, CA
Mar 13, 2004
  • Mar 13, 2004
my throwout bearing went out like 1000 miles after new clutch/bearing install. had to take it back and they redid it (fixed it). mine used to do that click a couple inches from the floor as well sometimes, not sure what that is. I have a spec stage 2 now with adjustable cable/quadrant, no noise anymore.
D
Dtowncats
340
York, PA
Mar 14, 2004
  • Mar 14, 2004
I hear a clicking noise every time, not just sometimes. Anyone else have any ideas?
M
motrV8ed
31
Hampton, VA
Mar 14, 2004
  • Mar 14, 2004
If you hear a clicking noise right when the clutch engages it could be the TO bearing or the pressure plate itself.
Black93SVT
363
North Andover MA
Mar 14, 2004
  • Mar 14, 2004
what sort of setup do you have? adjustable or stock cable? firewall adjuster? aftermarket quadrant? let me know what you have I've done more of these setups than i care to think about we'll definitly find the problem.
Usually if it you have the firewall adjuster and adjustable cable the cable wasn't tightened enough and the adjuster is screwed out too far. from what i could see with a flashlight inside the housing it looks like the T/O bearing is catching on the end of the bearing retainer... hence ur clicking.
had the same problem with both my car and two of my friends cars until we got the setup adjusted properly.
chris
D
Dtowncats
340
York, PA
Mar 15, 2004
  • Mar 15, 2004
Well I'm screwed because I believe my tranny is going. It's getting hard to shift into third and something clunks whenever I pull out anywhere. I'm only 17 and money is very tight seeing that I am trying to afford everything by myself. I don't know what I am going to do. Maybe a grad. present.
Anyway everything is stock except for the King Cobra clutch. Stock cable and quadrant. No firewall adjuster. Let me know what you all think.
Thanks
StreetStang37
451
San Jose, CA
Mar 16, 2004
  • Mar 16, 2004
could be your clutch isnt disengaging all the way, maybe your clutch cable is overly stretched, or the cable that helps hold the tension is screwed.
Black93SVT
363
North Andover MA
Mar 16, 2004
  • Mar 16, 2004
The stock quadrant is made up of two pieces. One or the other may be flexing as they tend to do causing it not to disengage properly. I agree wtih streetstang37 the clutch cable could be overly stretched. I'd look into getting an aftermarket quadrant and cable i don't think its your tranny. Only possibility as far as the tranny goes it could be the bearing retainer in the front. If its worn and theres a groove in it now the throw out bearing could get stuck not allowing complete disengagement. No worries though they're only like 60$ and you can get them from summit or hanlon motorsports or d&d. The question is how mechanically inclined are you to be taking apart half ur car to find out whats wrong....
Any Chances you live near me? I'm from Massachusetts.
D
Dtowncats
340
York, PA
Mar 16, 2004
  • Mar 16, 2004
No chances, I'm in southern PA. So what do you think I should do first to solve this problem? Where do you recommend I get a new quadrant and cable from and anything else I am going to need?
Thanks for all of your help so far all of you!
K.C.90gt
379
Detroit Area, MI
Mar 16, 2004
#10
  • Mar 16, 2004
  • #10
I too also think it is your clutch cable. I was having similar issues as you and the more I drove it the harder it was to enage a gear, it got to the point to where I could not even engage a gear. I looked under the car where the cable connects to the bellhousing and the stock cable was completely frayed apart with bare wire showing, it was almost to the point of snapping. Anyways I got a new cable and quadrant and installed it within a couple hours. No biggie. I got the FRPP cable & quadrant. It now shifts great and feels much better when pushing in the clutch. Summit sells some as well as others, do a search and you'll find many to choose from. You should do a visual inspection of the cable from the firewall to the bellhousing. Good luck.
Black93SVT
363
North Andover MA
Mar 16, 2004
#11
  • Mar 16, 2004
  • #11
Dtowncats do you have AIM? Yahoo or MSN? PM me your sn and we can talk more and easier there.
Chris
R
rdksek844
300
Port St. Lucie, FL
Mar 16, 2004
#12
  • Mar 16, 2004
  • #12
I had the same problem, and found that the adjuster nut on my cable where it connects to the fork had backed off, so when i tightened it the clicking went away. I also had a similar problem on my 95 gt and it was the firewall mount for the clutch was loose. tightened it and the clicking went away. try these checks and let me know.
StreetStang37
451
San Jose, CA
Mar 17, 2004
#13
  • Mar 17, 2004
  • #13
K.C.90gt said:
I too also think it is your clutch cable. I was having similar issues as you and the more I drove it the harder it was to enage a gear, it got to the point to where I could not even engage a gear. I looked under the car where the cable connects to the bellhousing and the stock cable was completely frayed apart with bare wire showing, it was almost to the point of snapping.QUOTE]mine was the same exact way.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
