Coupla questions...Alternator and Clutch on 03 Cobra
SVT98Snake
258
OK, USA
Ok....first the alternator.
This has happened twice. Once after I washed the motor, and again the other day as I was driving.
My battery light comes on. I check the voltage on the battery and it shows 12v....which indicates that it isn't charging. I cleaned the terminals and reconnected the cables....still only 12v.
On my way home, I decided to try something so I ripped on it right before I pull into my house and the light started flickering with more RPM.
The very next day the light is off and the battery is charging 14-14.5v. It hasn't come back on again.....
What is it? A loose wire? A qwirky voltage regulator?
Now the clutch...
After hard acceleration the pedal feels notchy....kind of like it needs oil to smooth it out. No slippage. But if I push it in 5-6 times, the pedal feel smoothens back out.
Bad cable or t/o bearing???
Thanks guys.
You know there's a problem with the alternators on these cars. They have a high rate of failure. Some say it's because water drips on them from the open heat extractors in the hood.
As for your other problem it sounds like a clutch cable problem, you still running the original stock t/o bearing?
U.M.
