couple timing questions
jd4x426
17
first off is this the spout conector and also would i be ok running 12* of timing on 91 octane with just some basic bolt ons thanx for any input
Yes, that is your spout connector. The only way to know exactly how much timing you can run with your specific setup, gas, and car is to experiment. Bump the timing one degree at a time and drive the car. Listen for pinging and feel for power loss or gain. At this point you will know how much timing you can run.
