crane cams rockers on stock heads?
SilverFox90
80
central, IL
a friend of mine has a set of crane cams gold roller rockers that he currently has on a set of trickflow twisted wedge heads.....he told me that he would sell them for 100$ i was wondering if they will fit my stock heads and if so does anyone know if they will clear the valve covers?
It depends on the ratio and overall size of the rocker body. I am pretty sure the problem isn't the rocker hitting the valve cover body, but 1 rocker can hit the oil baffle on the passenger side if you don't grind away at the baffle.
Will they fit = you can make them fit
If they don't = sell them to me and I'll make them fit.
Twisted Wedge heads are stud mount, the stockers are pedestal mount. They wouldn't work without machining the stock heads for studs, unless there's some kit to convert the roller rockers to pedestal mount?
