Crane Hi-6s Ingnition
  • Thread starter Thread starter skiwesser11
  • Start date Start date Aug 26, 2014
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Rock Hill, South Carolina
Aug 26, 2014
  • Aug 26, 2014
It just died all of a sudden, plugged stock coil plug back in to run off the stock ign. Tried box again next day, ran a few seconds and died.
I'm getting 12v constant on both sides of coil with crane box plugged in.
Only using basic hookup, not using retard or 2 step deal.
Think it's fried? What else can I check?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 27, 2014
  • Aug 27, 2014
If it works OK when you wire it up in stock configuration without the Crane box, then the Crane box has died. To the best of my knowledge, they are not repairable by anyone but Crane.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Aug 27, 2014
  • Aug 27, 2014
sounds like its dead
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 27, 2014
  • Aug 27, 2014
That's odd because I rarely hear of a Crane box crapping out, MSD all the time. How old is the box?
V
venomisback
  • Aug 27, 2014
Same thing happened to me last year.
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Aug 27, 2014
  • Aug 27, 2014
About 10 years but only about 18-20k miles on it. Works intermittently,but no lose wires. Drove today for about 5 mins. Drove fine, no cutting out, missing or anything.
Has never cut off while driving, but when ignition is switched off will not restart.
Testing with light, it still flashes even though car won't start.
Again with stock ignition all is well
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Aug 28, 2014
  • Aug 28, 2014
So general consensus is to get another hi-6?? What are you guys running??
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 18, 2014
  • Sep 18, 2014
Well it's dead for sure, all connections are good. I try it every few days and it hasn't fired with hi-6 hooked up since post.
I really don't need aftermarket ign right now but will when I spray it and I really really want to hook the 2 step up to the clutch switch, that will be awesome.
I didn't really realize that ign box had that feature and neither did my bro (who is the actual mechanic, both of them. I am far from it however). The one that installed it isn't in to racing so he didn't pay attention or mention it I guess, he just put it in.
Is there a wire from the clutch switch that is hot when clutch is depressed? Seems it would be simple to hook up, am I correct??
2000xp8
Aug 8, 2003
8,060
1,644
194
NJ
Sep 19, 2014
  • Sep 19, 2014
I don't think you need an aftermarket ignition at all.
Wait until you get a power adder.
Admin Dude
Jan 4, 1985
43,418
21,628
234
Box behind Walmart
Sep 19, 2014
#10
  • Sep 19, 2014
  • #10
This... and even then it may not be necessary.
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 19, 2014
#11
  • Sep 19, 2014
  • #11
Last engine needed it on spray so I am going to replace it before I start using on this motor.
2000xp8
Aug 8, 2003
8,060
1,644
194
NJ
Sep 19, 2014
#12
  • Sep 19, 2014
  • #12
How do you know you needed it?
I ran 100 dry shot without one, it was fine.
Admin Dude
Jan 4, 1985
43,418
21,628
234
Box behind Walmart
Sep 19, 2014
#13
  • Sep 19, 2014
  • #13
The reason that these questions are being asked is because the OEM ignition system on these cars is PRETTY DAMNED GOOD even by after-market standards. Quality control of the OEM pieces is significantly higher than that of the after-market.
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 19, 2014
#14
  • Sep 19, 2014
  • #14
Well when I first installed nitrous system (wet system w/one fogger) I forget jet sizes but equated to like 135 shot via online calc.
Heads were stock E7's that had been milled I think .030 (could that be right?) stock cam with pedestal 1.7 "cobra" r arms, pullies, headers ect...
Car ran really well but when installed nitrous system it would like hesitate and pop a little sometimes. My buddy had a new Crane hi-6, cured the problem so I left it alone. Never sprayed the motor previous to this rebuild but all parts still in car, bottle heater, widow switch ect. So I will use the system again.
Again, for now I mostly want it just for launching on the 2 step. I just like to say 2 step
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 19, 2014
#15
  • Sep 19, 2014
  • #15
Can you send them to crane for reman??
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 20, 2014
#16
  • Sep 20, 2014
  • #16
2000xp8, you know everything about my motor and most about car. What do u think I'll run in 1/4 and 1/8mi? 1/8th mi tracks are all we have around here so it'll prob never see 1/4mi on track.
Not sure what u don't know:
3.73's mt et streets, or my old tall McCreary dirt track tires that always hooked like glue.
2000xp8
Aug 8, 2003
8,060
1,644
194
NJ
Sep 21, 2014
#17
  • Sep 21, 2014
  • #17
Should be 12.50 or better.
There is probably 11 second potential (i've seen less go faster), but an 11 second timeslip is never a given.
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Sep 21, 2014
#18
  • Sep 21, 2014
  • #18
That's just about what I was shooting for, high 7's in 1/8th
  • dan50
  • Jul 18, 2026
dan50
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
