Crank no start list
  • Thread starter Thread starter Creomod
  • Start date Start date Dec 16, 2020
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
  • Dec 16, 2020
Question,on the crank no start list on the tests you perform it says to look for 12 volts fuel injectors, if I have “low” voltage there like 11.47 volts is that considered 12 volts. Reason is it says you can have voltage in all the right places but the computer needs to provide ground. So does less then 12 volts mean something is wrong or am I ok?
$wine
25
Texas, USA
Dec 16, 2020
  • Dec 16, 2020
Personally I think that’s close enough to be considered 12v. The experts may say otherwise.
Reactions: Creomod
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
  • Dec 16, 2020
I’m chasing my tail here. I thought that as well but what do I know. My car is cranking but I’m noticing the lights getting dim like the battery is low. I put voltmeter 11.97 on the battery so I’m trying to find out why I’m getting that low voltage in the coil both sides and the fuel injectors?Im assuming my cars not starting because I don’t have exactly 12 volts where the list says it should.
$wine
25
Texas, USA
Dec 16, 2020
  • Dec 16, 2020
Try a jump start see what happens.
D
Deleted member 215073
Dec 16, 2020
  • Dec 16, 2020
How are your battery terminals and posts? Are they clean? Have you load tested the battery? What does the voltage drop to when cranking?
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
  • Dec 16, 2020
I’m going to try that tomorrow. I was going to take the dash out to check my ignition wires. My red green wire has green inside the wire. I’m hoping this is the issue. I’ve done almost everything with exeption of using starter fluid.
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
  • Dec 16, 2020
New terminals nice and clean. The voltage drops to like 8or 9 volts when cranking. Since I have been doing these tests I’ll drain the battery scince the cars not starting and take it to autozone they charge it and they keep telling me it’s a good battery.Haven’t done a load test, how do I do that one?Thanks guys for the input by the way.
D
Dec 16, 2020
  • Dec 16, 2020
If they are telling you the battery is good they probably tested it for you. If I were you I would go buy a battery charger so you don't have to keep removing the battery and taking it somewhere to charge.
Did you do the crank/no start list in order? You can't skip any steps and start from the beginning even if you know the test will pass.
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
  • Dec 16, 2020
Yes I swear I have. The only thing I saw that looked bad was the 3 capacitors had green on them but had them changed the other is the is that green red wire because it has green corrosion I’m thinking it’s not letting enough voltage go to the ignition during cranking. I just changed the ignition switch with the new pins. Also I have 130 alternator new with 4 g wire. It’s new too not sure if it works though.
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
#10
  • Dec 16, 2020
  • #10
Reading through the list it says the ignition fuse link could be “blown open “ does that mean like blown exploded? Would I be able to see that visually?
D
Dec 16, 2020
#11
  • Dec 16, 2020
  • #11
Open indicates no connection or causing an open circuit.
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Dec 16, 2020
#12
  • Dec 16, 2020
  • #12
G
JMGlasgow said:
Open indicates no connection or causing an open circut
O god. How do find one that’s doing that?
D
Dec 16, 2020
#13
  • Dec 16, 2020
  • #13
I'm not sure where exactly they are located.
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
D
89 foxbody fuel pump not priming
  • Dubsantana
  • Jul 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
