  • Digital Self-tuning Forum
Crank no start on a turbo and cammed pushrod 5.0
  • Thread starter Thread starter 1630stri
  • Start date Start date Sep 2, 2026
1630stri
Hutchinson KS
Sep 2, 2026
  • Sep 2, 2026
Hey guys, looking for some help here. recently got tasked with getting a 1989 mustang running again. its a pushrod 5.0 automatic. its current got an f303 cam and stock pistons. rockers have been upgraded but unsure of the heads. was told it has 60lb injectors. currently also has adjustable timing gears installed at the 4 degree mark on the crank gear (making it a 2 degree advance on the cam gear) and distributor locked down at 10 degrees. owner also installed a standalone microsquirt ecm that plugs into factory harness. needing help to get a base line tune to even get the car started. its currently stuffing a crank no start and dumping a lot of fuel. been struggling for a couple days and needing help
Qtrhrse23
78
29
28
Texas
Sep 11, 2026
  • Sep 11, 2026
A base A9L tune (MS has downloadable base maps)should fire her up and run. Is it even attempting to start. Fuel pump primed? Checked fuel pressure?
Two things I ALWAYS LOOK FOR. Is it firing AND is it getting fuel. THAT WORKS ON ANYTHING. From weed eater to big body 1000K Hp engine.
Qtrhrse23
78
29
28
Texas
Sep 16, 2026
  • Sep 16, 2026
Guess they got it.
Reactions: Mcmahst
  • dan50
  • Jul 18, 2026
dan50
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
