Engine Crank, no start on cold start.
  • Thread starter Thread starter amkullar
  • Start date Start date May 5, 2019
First Prev 2 of 2
C
C Chastain
Clovis ca
Jul 20, 2025
#21
  • Jul 20, 2025
  • #21
I have a 65 fastback that I transplanted a 91 EFI 5.0 HO in, put in a Holley EFI tank and pump. I ran the fuel lines straight from the tank to the stock fuel rail. If it sits for a few hours it looses fuel pressure and won't start. I shoot a little starter fluid and it starts right up. I can drive it all day and it starts fine. let it sit for over 3 hours and no go. Good filter, good pressure, replaced the fuel regulator and that didn't do anything. When I turn the ignition key on and the pump comes on, it continuously runs and doesn't shut off, like it's not building up pressure and shutting off by itself. should I have something in the supply line in addition to the fuel filter?
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,515
2,936
173
Florida
Jul 21, 2025
#22
  • Jul 21, 2025
  • #22
Sounds to me like you lose your prime and the pump cannot " reprime" itself... Are there rubber hoses " inside" the fuel tank?? I would check these for any wear, cracks or holes...... While I was inside the tank I would check all of the connections to and on the pump..
AeroCoupe
6,167
4,264
183
Claremore, OK
Jul 21, 2025
#23
  • Jul 21, 2025
  • #23
First have you checked for any codes? Second, when you turn the key the pump should only prime for three seconds then shut off. Typically when the pump continuously runs the ECU needs to be repaired.
General karthief
Mod Dude
Aug 25, 2016
28,085
10,699
213
polk county florida
Jul 21, 2025
#24
  • Jul 21, 2025
  • #24
Being a transplant to a 65 model there could be several issues, this thread is a few years old.
You need to start a thread here:https://stangnet.com/mustang-forums/forums/fox-engine-swaparoo.250/
be detailed about the car history and mods and maybe a pic or two for those of us that are not readers.
First Prev 2 of 2
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
