Cranking Problems !
Pete3983
10
I posted on here about a month ago and used the checklist that was posted. Story is my car wouldn't crank when I put the key and turned it . I was told ignition switch, neutral safety switch key lock cylinder. I connected the two bolts on solinoid and the car cranked. I have no power on the ignition wire that connects to the solinoid when I turn the key. I replaced the ignition switch and overrided the neutral safety switch by disconnecting it. I've :bang: Any help is appreciated Thanx !
You shouldn't need to bypass the neutral safety switch unless its bad. Just put the car in neutral or push in the clutch.
If your not cranking with the key but you are when you jump the posts on the solenoid than That right there might be your problem.
Are you taking measurments with a multi meter? You may have a bad Solenoid switch. Which is mounted on the driver side firewall.
You noted no power on the S-terminal wire. Start tracing the wire to see where you lose power (the likely spots are at the ignition switch itself and the CSS). I know you checked them but I'd check them again since this seems to be an issue.
Good luck.
I replaced the solinoid this morning so thats new and i have power on it. The S terminal traces back to the ignition switch I believe I only have power on the two battery wires on the ignition switch.
Diagrams courtesy of Tmoss & Stang&2birds
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
Thanks Richker for the diagram in color. I have the wiring diagram but it doesn't go into details like that one. It just shows the color and the number it corresponds to. I think I might have a faulty ignition switch so I'm going to change it out.
