Cranks but no start, backfiring through intake.
  • Thread starter Thread starter RacEoHolic330
  • Start date Start date Aug 30, 2006
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Aug 30, 2006
  • Aug 30, 2006
I'm trying to get my car started but I'm not having luck. I looked at the checklist on the forums and I confirmed that I have fuel and spark. I checked a plug and its wet and I also checked that there is spark at one of the spark plugs. I'm 99.9% sure I have the dizzy set in the correct position. The #1 piston was at the top of the cylinder and the dizzy rotor was pointing at the #1 plug.
When I crank the car for a while, I get loud pops that sound like a backfire through the intake. There are no signs that the engine wants to fire up, it just continues to crank.
I also noticed that my fuel pressure is bleeding off faster than it used to. It used to take a couple hours to get to 10 psi. Now it happens in about 15 minutes. I don't know if that means anything.
Also, is there supposed to be 12 volts at the coil wires when the ignition is on? Because I checked mine and I'm not getting anything.
The only thing I didn't do is mess around with the dizzy. I flipped it 180* just to make sure and it didn't help at all. Maybe I can try clocking it to different positions and see if that helps. I'm really confused and could use some help. Thanks guys.
M
Mike92GT
583
Florida
Aug 30, 2006
  • Aug 30, 2006
You could have the dizzy off a tooth. You might try putting the motor back to TDC and re-installing the dizzy again just to be sure. Also, double-check your firing order. I managed to mix up two plug wires last week even though they are all labled.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 30, 2006
  • Aug 30, 2006
+1 .... had a similar situation but was able to get it running - it just ran like crap. What has changed since it ran last or is it a new motor?
68torinogt
Hey guys, guess what--I have a bi-pass!!!
Mar 21, 2006
Welcome my son, welcome to the machine
Aug 30, 2006
  • Aug 30, 2006
what about a injector or all of them being hung in the open position?
your plugs shouldnt be too wet.
68torinogt
Mar 21, 2006
Aug 30, 2006
  • Aug 30, 2006
i agree with the plug wires being crossed alsoView attachment 444134
RacEoHolic330
4,014
1,698
203
Allentown, PA
Aug 30, 2006
  • Aug 30, 2006
Checked the plug wires and firing order, they are fine. The plug was wet but it wasn't soaked. I'm going to try the starter fluid method and see if that solves anything.
I had the engine torn down to the block, and I installed new valve springs on my heads. I carefully reassembled everything so there shouldn't be any problems there.
I'll try rotating the dizzy to a different tooth and see what that does too.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 30, 2006
  • Aug 30, 2006
180 out if it's firing through the intake. The rotor will still point to #1 on the cap 180 out. This will ignite the fuel with the intake valve open = backfire through the intake
RacEoHolic330
4,014
1,698
203
Allentown, PA
Aug 30, 2006
  • Aug 30, 2006
Got it running. The dizzy was simply about 90* off or so. I should have known that was the issue. My idle is surging a bit, but I'll take care of that soon. Thanks guys
68torinogt
Mar 21, 2006
Aug 30, 2006
  • Aug 30, 2006
thats kinda what i was thinkinView attachment 444028
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
