I'm trying to get my car started but I'm not having luck. I looked at the checklist on the forums and I confirmed that I have fuel and spark. I checked a plug and its wet and I also checked that there is spark at one of the spark plugs. I'm 99.9% sure I have the dizzy set in the correct position. The #1 piston was at the top of the cylinder and the dizzy rotor was pointing at the #1 plug.
When I crank the car for a while, I get loud pops that sound like a backfire through the intake. There are no signs that the engine wants to fire up, it just continues to crank.
I also noticed that my fuel pressure is bleeding off faster than it used to. It used to take a couple hours to get to 10 psi. Now it happens in about 15 minutes. I don't know if that means anything.
Also, is there supposed to be 12 volts at the coil wires when the ignition is on? Because I checked mine and I'm not getting anything.
The only thing I didn't do is mess around with the dizzy. I flipped it 180* just to make sure and it didn't help at all. Maybe I can try clocking it to different positions and see if that helps. I'm really confused and could use some help. Thanks guys.
